Sorry Chad, I have been in Mexico. I will grab a measurement tonight when I get home.
So I am putting my quest for a CA street legal 818R on hold. This car is going to be a dedicated track car until spring at the soonest.
For those of you wishing to register your car in CA be aware. I failed my brake and light inspection today.
Before my test I made sure the dashboard illuminated for my parking brake, high beams and blinkers. I had my rear license plate illumination lights working, backup lights and blinkers/hazards working. I thought I had all my bases covered and most of the failures came as a surprise.
Here is the fix list:
- Rear backup and turn lights are LED and not DOT
- This one is tough. The only thing i can think of is to drill a hole in the rear and put a white DOT surface light then replace the existing turn signal with an amber DOT surface light. Ugh - Turns signals must auto cancel
- Install stock steering column and wire up. Ugh - Head lights are at 20.5 - must be at 22"
- Put front suspension at street height, tighten front coils. They wont pass 21.75 so if its still short i will get larger diameter donut tires on a temporary rim to pass. UGH!! - Brake hose close to tire at full crank
- Need to adjust - Proportioning valve not DOT
- Bypass valve - Steel braided brake lines not DOT
- Replace lines with rubber DOT lines - Rear reflectors missing
- Find and install - License plate lights LED and not DOT
- Find DOT license plate lights
So instead of dealing with all that nonsense I am going to rebuild my motor instead. I want more HP and there is an underlying issue with my bottom end. That noise the gopro was picking up is now noticeable while driving. Scargo you were right again darn-it. I think it's a wrist pin.
I'm taking this opportunity to do a 2.2 stroker. First thought is STI crank, manly pistons and rods, garrett turbo, align hone block and perhaps more depending on what i see once in there. Racing tolerances.
I'm debating an LSD but think i might stick with my first plan and wait to grenade my 5spd and take the LSD built into the 6spd when the time comes.
I am bummed to be out of commission but plan on building a stronger more durable race motor so in the long haul its for the better.
Metalmaker, we are in the same boat now buddy!
