Thanks- Chad
I can dig it.
Pretty nice! Part of the 70% success, I guess.
Your rad fans and shroud look cool, I see mishimoto on them, any model, specs or something? If you already mentioned all that, could you remind me when in time or post #/page you think that could be?
Tracked May 27/July 26, 2017
Build Completed Winter 2021
Thanks- Chad
Found it on amazon $220, not bad. I have the older style rad with the inlet on the top right corner so not sure this model fits. I'll check on mishimoto's site. Good lead.
I have been a designing fool today. Maybe because it is 106 degrees today and the garage is hot!
Lower is bracket done. The more I use this thing, the more I love it. I should sell some of this stuff
Dyson loves barking at the 3D printer....
Lower tank knob "pops" into the bracket hole snuggly.
All mounted up-
I also bent the rear firewall another 10+ degrees so it clears my seat. My powder coater had an old school break that would fit the whole firewall. I need to rivnut and mount that when its cooler.
Thanks- Chad
I have an air conditioner in my insulated garage... it's noisy but so am I!
Dan
Well, yeah! Why not? I bet if you can build a full wiper system that doesn't need a cut in the hood you'll pay off your 818 in a few weeks.Ok ok, 3D printers are not "that" good yet.
But bracket-wise, it's awesome and if I decide to use the same parts as you, at the same location, darn I'd love to get your brackets.
You are lucky! I talked with the "Boss" of the household. Once we finish the first phase of our backyard, I getting an A/C unit for the garage. I'm out there too much to be uncomfortable.
Pics of the re-bent firewall before rivnut central. I need to take the seat out and start drilling.
Thanks- Chad
I REALLY like the 3D printed parts, the quality of your parts is extremely good. What kind of printer do you have? I just got my own printer, and am looking forward to using it exactly like you are. Mine is a QU-BD Two-Up, about as cheap as it gets ($300). It also is pretty limited in capabilities, but the price can't be beat. You might answer this question when you tell me the kind of printer you have, but you really can't print in PLA? It has a lower extrusion temperature, and is usually regarded as easier to work with.
After just getting mine and all of my friends telling me "print me a _____!!!", I can't tell you how many times I have had to explain how hard printers are to get perfected, and that they aren't just press and play. -_-
Haha- Yeah- I have my friends wanting me to print them stuff for their car's..... It's not that easy AND they want me to design the part..... That takes the most time. Half the things I make around the house, my wife either loves (Razor holders in the shower), or hates (Frother holder that attaches to the Keurig)... The kid loves I can print him stuff for his Legos (one off parts).
I have the Makerbot Replicator 2X- It's the ABS model. From what I have been told and read, ABS is a little more finicky to work with, but melting point is much higher on ABS than PLA (this is good for race cars depending on what you are making). Its also stronger. I think that is important for what I am making. The build plate is kept at 120-130 degree Celsius, then the nozzles are at 230-240 degree Celsius (~464 degrees F).
A good source on the pro's/ cons of PLA and ABS:
http://www.absplastic.eu/pla-vs-abs-plastic-pros-cons/
The other cool thing is anything I make can be made out of aluminum. I can use the same design file and send it to a CNC shop. So I can prototype in ABS make sure it fits, then can send to a CNC shop (eMachineshop.com). Its pricey, so it pays to be making alot of parts to sell. I have a local guy now.
Either way, PLA or ABS you are going to love it.
Thanks- Chad
I'm pretty familiar with the differences and pros and cons of using either, and I definitely see why you use ABS for the car! I just haven't dealt with any printers that can only do ABS, because usually they can do PLA if they can do ABS. I think the Makerbot build plate is what keeps you from using the PLA due to the high temperature, but I have seen some work-arounds you might try if you ever felt the need. But hey, if you don't have any problems with it, then there you go! Might as well just leave it be.
As for 3D modeling, that's the easy part for me, being a senior Mech. E majorI have Solidworks, and it almost spits out the models faster than I can think of them. Fiddling with my $300 printer is what consumes my time... I hear you about expensive CNC shops too, that's why it's on the list of things to get eventually
Have you ever looked into using a Techshop, or something similar? They let you do the machining yourself, if your interested in learning how. Of course, your time might be much better spent just ordering the parts.
I was in prototyping, but out of it now for 12 years. Chuckle. Actually doing some pro bono consulting today for a friend with products he wants to develop.
Have you looked into investment casting VS machining? ABS RP, with its limitations, always makes me think of metal castings. Any local foundries? I know people are doing it and some use PLA patterns. Don't know what materials can be swapped out to run in the personal/home grade printers.
My specialty was urethane casting in RTV silicone rubber molds. Glass-filled, high impact with molded-in inserts. Not great around high heat. Would be good for some things.
How about getting SLS parts made once your design is proven? I haven't a clue where prices are now for prototypes.
PS: don't forget radii, fillets and customizing. Those are almost free in RP and can make the parts so sexy and unique.
"Scotty, give me all the TRACTION she's got!" Pictures of what I drive till 818R is finished
Track Car Journal on IWSTI (with build info)
I've had people say "hey, I need this part to interface with these two other parts (neither of which I have). If i send you a picture I found on the internet can you make me one? lol. Don't think I can take a cell phone pic of an item taken at an angle and make a part that is +/- .005"People who have never used cnc's/printers/etc under estimate the work required to spit out parts.
Zero Decibel Motorsports
Check out my new website!
I'm a total Newb with this stuff. I just started it once I received the 3D printer for Xmas from my Wife. So I have no clue what you are talking about...lol I'm just enhancing my 818R build using some pretty cool tools.
I know how you feel..... I had someone ask me to print a gun part......
Thanks- Chad
Ya, but can it make a cup of Earl Grey?
Thanks- Chad
Yep- Edit.....
I ventured into the garage and finished the upper rear firewall with rivnuts. I'm digging those aluminum washers that Sixstar told me about.
I tried to cover the "factory drilled" holes with no avail.... one was going to show no matter what, or the spacing would not be equal... I wish those guys in shipping would take some time and measure. That way we do not have to deal with their unsightly holes- at least be uniform.
Thanks- Chad
Where did you get those washers?
Those are from Allstar Performance aluminum countersunk washers (Summit/ Jegs). I got the 1/4" ones.
Thanks- Chad
Chad, how about printing a wiper motor to transmission bushing. Mine cracked on my WRX and apparently they don't sell them separate from the wiper transmission. You'd make a small (literal) fortune
I'd send you one to scan and print but mine has disintegrated.
Thanks- Chad
Thanks- Chad
Mr. Plavan, have you looked at chassis lift points yet for the track, like adding frame tube front and rear on each side to allow one to slip in a jack bar, as the car is going to be low and was looking not to have to repeat the issues I away have with my challenge car and lifting that for up minor work at the track? I was thinking something like this or any other ideas folks may have
Tony Nadalin
2022 SOVREN Championship
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
The 818 is there lowest car so this will be a good idea
Thanks- Chad
I had to buy a special low profile jack to get under mine when done. If I had a flat I am not sure even that would work. I like the frame tube idea.
Why not go with air jacks? By the time you do all the work to modify the frame and use jacking inserts you could be halfway to air jacks. Plus, the weight of the 818 is not so high that you could not afford air jacks. Seems to me the tune of the engine could easily handle the weight.
Frame mod will be under $40 depending on where I put them, the main issue will be body. I'm looking to go cheap, while air jacks are nice, just something else that I have to service like the lines, couplings, seals, etc. and also having high pressure nitrogen tank at track
Tony Nadalin
Well the airjack money will surely be gone for now. After a few of the 818 track car motor problems- I'm thinking about ditching my whole Killer B setup and going Drysump. I would hate to mess up my new built motor on the first time out. I have the drysump system on my vintage race car (stock) and never had any problems oiling wise. I'm still researching.
Anyone know if you go to an Drysump setup if you still need a AOS?
More printing fun- My version of a Steering Column spacer-
I did 80% fill (100% would be solid block) Stupid strong- as reference the Blue protoype is 20 or 15% fill (honeycomb) I stopped mid print- I think 20% would of been plenty strong for this application.
Thanks- Chad
You're really getting me interested in a 3D printer. I have always wanted one but never could justify the reason. Your improving on your design skills, nice looking piece.
I tried using a low profile jack but at R height i still can't get under the car, especially if I take a path crossing over the valence. I have been driving the car up onto 2 X 4's so i can get the jack underneath it. I like the idea of a lift point, but the side panels come out so far from the side tubing i don't see how you would accomplish it. Lead the way
Brandon- Thanks- They are alot of fun. The software is limiting my imagination. I need to look at other programs.
The only problem is, you start thinking about other things you can make, then never spend time working on the actual car.
I did cut the front UCA's like you- I got -4.5 degrees on one side....lol. I adjusted back to -3, but it's nice to know the adjustment is there if needed.
Thanks- Chad
Can't wait for 3D printers to print through an alu block!
Jeez, nice.
Was checking them out and DrySumps are $3,500? You have to be kidding me....that's how much stroking the motor would be. I thought the killerB baffle helped with sloshing oil so i'm wondering why that alone isn't adequate? The only negative I heard about them is that they starve the motor on start-up but wouldn't an Accusump take care of that? I have a killerB pickup and baffle on my motor now. The more i read the more I'm realizing the stock bearings are garbage. I'm leaning towards a new bottom end with quality parts and an accusump and calling it a day. DrySump is getting to cray cray for me
No. That never happens. Ever.
The baffle is meant more to control oil returning from the heads and prevent it from sloshing onto the crank during jerky movements (ie: hard shift). It doesn't do as much to prevent oil from pooling in the head during an extended high G turn.
I'm not seeing a lot of issues with stock (slightly modified) Subaru engines for road racing as I'm out with these guys and they continue to run w/o too many issues, I can see more issues with auto-x and rally.
Tony Nadalin
