I had stomach issues in the last week to 2 weeks. Which lasted until I crossed the Canadian border on my way back. Then I shouted at the Canadian border and Transport Canada cuz I succeeded through my first huge step and I was so happy. loll Good thing none of them heard me, it wasn't pretty. lolll
I test fitted the shaft with and without that valve and didn't see any difference. The thing is, it was just by hand, not on the car and driving it, so I don't know if under load (steering load that is, not engine) it will be ok. Others have trashed that valve too so that's why I decided to do it as well. On the long rod though, some have remove everything but the end cap. Mine looked a little different than most of the pix I've seen here, still I tried to remove all but there was a bigger piece I had to keep on one end of the rod, otherwise the rod was moving up and down and that was bad.
Back to the shaft, mine is maintained solidly in place by the bottom bearing and the very bottom tip of the shaft, the portion that goes in the hole inside the rack itself and maintained a little by the upper rubber (but that's just a rubber). I hope I am not wrong, I still have the valve, so if I have problems, a couple of days work to remove the rack and put back the valve would be ok, though not very funny.
I don't think the valve is harming anything anyway and it's not like you are adding 100kg to the car for so little benefits, so I say you did good.
