0
0
Originally Posted by
Frank818
Rasmus, I can't see the tools you used to cut the axle stubs, what are they?
See you can. I recommend using a 5 inch cut off wheel. The 4 1/2 comes up a hint short when you've used it for a bit.
MrDude_1
I would bet money he used that angle grinder and a cutoff wheel for the majority of the work...
Disco.
