0
0
Originally Posted by
FFRSpec72
For the R this would have to change as legally (in most racing bodies) you can't have any electrical power going anywhere if the kill switch is thrown.
STiPWRD
My odometer turns off when the key is out of the car. I thought the mileage is stored in the EEPROM chip - otherwise the mileage would clear when the odometer was removed from the car.
I'd double check the wiring
It is fine to turn off the 12v to the cluster when the key is off or the battery switch is off.
The main odometer is stored in eeprom so that info is not lost.
The TRIP odometer is stored in ram and will be lost when removing power from the cluster.
There is also 12v hot going to the Subaru ECU. If you turn it off you lose it's learned memory.
After momentarily disconnect my Subaru battery, the engine take 3-4 revolutions to start. Normally 1-2.
