Thread: Odometer always on?
    Cranston, RI
    Odometer always on?
    Hi, I pretty much finished my wiring harness, but I noticed that my odometer always displays the mileage even when the key is not in. Anyone know what I messed up here?
    Quote Originally Posted by Justen View Post
    Justen
    That is the way it is suspose to work.
    There is a hot wire going to the cluster that is used to display the odometer and to remember the the trip odometer miliage when the key is off. It puts a very small drain on the battery.
    Congrats on finishing the harness.
    Cranston, RI
    Bob,
    Thank you! I thought I did something wrong.
    Kirkland, WA
    Justen
    For the R this would have to change as legally (in most racing bodies) you can't have any electrical power going anywhere if the kill switch is thrown.
    Tony Nadalin
    2022 SOVREN Championship
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    Leesburg, VA
    My odometer turns off when the key is out of the car. I thought the mileage is stored in the EEPROM chip - otherwise the mileage would clear when the odometer was removed from the car.
    I'd double check the wiring
    It is fine to turn off the 12v to the cluster when the key is off or the battery switch is off.
    The main odometer is stored in eeprom so that info is not lost.
    The TRIP odometer is stored in ram and will be lost when removing power from the cluster.
    There is also 12v hot going to the Subaru ECU. If you turn it off you lose it's learned memory.
    After momentarily disconnect my Subaru battery, the engine take 3-4 revolutions to start. Normally 1-2.
    Lake Forest, CA
    The reason is takes longer to start on your car after an ECU reset is because you have a DBW equipped car. It's calibrating the DBW system and will not start until it completes that process (this could be considered part of learned memory). Basically it's the time is takes on an STi cluster to do the gauge sweep. Non DBW ECUs will start on 1/2 revolutions even if the ECU has been reset.
    When we say to our customers "if there is anything you need, please ask," we mean it.
    iWire Subaru Wiring Services
    Over 100 Custom 818 Wiring Harnesses Built
    http://www.iwireservices.com/factory...18-wiring-kits
    sales@iwireservices.com
    Quote Originally Posted by iWire View Post
    Thanks Brian
    We are all still learning. Don't stop.
    Lake Forest, CA
    Thanks Brian
    Here to help.
