Would also recommend that you use something like HyperKuhl to prevent corrosion and help heat transfer (I get maybe 5 degrees cooler when using this stuff) but after a season of racing when I drain the radiator/engine the solution is still light blue, no rust and the aluminum is not pitted/corroded.
