I have argued for over an hour with the gas pedal, mounting bracket, pedal box and the firewall.
When I put the bracket pedal assembly up to the fire wall, when the gas pedal is depressed, it will hit the clutch bar on the clutch/brake pedal box. Is this correct?
It seems like there isn’t much movement or throw on the throttle cable if the assembly is mounted according to the directions, not to mention that the drawings in the book don’t reflect the actual size and shape of the bracket.
Is there a different bracket or am I missing something??
Oh yah, and how do you get the throttle cable through the firewall?
