Hey Rasmus
Do you have any advice on removing ABS sensors from rusty spindles?
To get the link bolts out of the spindles I cut between the arm and the spindle. Then used a pneumatic hammer from harbor freight to drive it out.
http://www.harborfreight.com/air-imp...kit-92037.html
The hard part is getting the bolt out of the lateral link arms, if you are trying to save the bushing.
Did you have any trouble getting the ball joint out of the front spindles?
