I have been using galvanized heat shields for years now on the GTM. Except I took the metal, folded it, added 3 layers of fiberglass cloth inside and hemmed it. Bent the edges for the stand off and hose clamped it to the muffler. Dropped the temp on the CV boot about 120 degrees. Also, using the heat wrap...follow the directions and you won't end up with a pile of fragmented cloth you can never use! Soak it in water, then wrap, let dry, and paint with high heat aluminum paint(2000). My wrap looks better after a year of racing than when I installed it.
