I made this chassis dolly but don't laugh at the extra holes and splices because I made it from the AJW crate wood. This holds the chassis at the engine mount cross bar so I can add the engine and transaxle without it becoming tippy to the back, and it's much more stable than jack stands. The bottom of the frame is 16" above the floor and easy to crawl under. As I did with a roadster, I'll have the engine running and about everything else installed before I have to buy wheels/tires and lower it from the dolly. To remove the dolly, I made the four blocks removable so I can put my jack on some 2x8's to reach the frame, jack it up, remove the blocks, lower it to the base cross piece, jack it up again and remove the dolly from the side. If you will have Stewart deliver your 818, I suggest you don't mount the small 2x2 pieces on the rear blocks but just have the driver set the frame on the four blocks. Roll it into your garage, remove the body panels, position it exactly and then screw on the small blocks to lock it in. You can probably improve upon this design so please post what I should have done.
Pete
9/16: See Post #19 for slight revision
7/22/14: another slight revision. Others have good suggestions so read through this thread before sawing 7 bolting.
The crate stuff DOES need cleaning, and I need to install my Grimmspeed ported/polished/ coated intake manifold to the engine along with my lightweight flywheel and clutch, depower my steering rack, install my Quaife LSD (if it ever arrives) and a whole mess of other things. I don't actually need to split firewood, but I do need to bring the electrician in next week to wire the garage for the electric heater. But no self respecting Minnesotan would ever have an outhouse that wasn't insulated from the gitgo -- however, I actually do need to insulate the garage! The ice fishing house is a folding portable (yes, I really do have one), so stocking it is a little difficult...............
