Results 1 to 40 of 226
Thread: Bob and Mike's 818Se Build Thread
Threaded View
  1. #11
    Freeport, ME
    Looks familiar... Check my thread and Mechies...
    I found that I couldn't use the heavy metal washer on the inside of the LCA bushing and get them to align. Remove them and retorque, I think you will find that they align better.
    Insert the front bolt through and rotate the arm forward to align the bolts. Check front to rear position with a straight edge (broom handle test) to make sure that both of the control arms position the arm at the same distance from the straight edge across the frame brackets. After you have done this you can determine where you may need to grind to adjust the holes. Can't tell from the photos, make sure the LCA bushing has the slight indent on the bottom of the bushing. I found that the arms were positioned the same using the frame's lower mount holes and I had to "adjust" the upper holes slightly... I adjusted the aluminum bushing on the right (side to side alignment issue) and the steel bracket of the left upper mount (front to back issue)
    http://thefactoryfiveforum.com/showt...-Build-Thread/ see posts 95 & 124 photos
    Dan
