VD2021
Nice digital display.
Very similar to the digital IP some of the Gen1 Guys have.
What are you plans for concealing the view of the PCBs through the smoked plexi?
How is the clearance/view of the fuel and coolant temp gauges with the column section cut and the column in place?
I plan just to leave it as is. You can see the PC boards, but they are really obscured by the smoked Plexiglas. I've left the panel hooked up to a 12v source for 12 hours, seated on a bench in my shop. If am 5 feet away, I don't see the PC boards. Now this could just be the way my eyes work. I figure when I'm in the car, I am at most 30 inches from the Plexiglas. What I notice are the LED readouts.
When I get back to the car, I need to do some preliminary fitting of the gauge panel. If it is too tight, I'll just raise the dash a little bit. I can't be more than a half inch either way.
This was a side project I took with me on my trip south. The really big deal this year is the Porsche 991 Transaxle arriving from Gbox in July!
Thanks!
