That is an extremely shallow pan. With the pickups on the drivers side and the crank rotating in the clockwise direction from the front of the engine perspective this may add to issues with windage and oil frothing. If I were you I think I would look at, at least, putting the scavenge pickups on the passenger side of the pan. Or make the pan deeper and use a windage tray between the pan and crank. Best case is you are giving up performance with this shallow pan, and worst case it could lead to premature engine failure. You may want to talk to the people at Dailey Dry Sump about design and maybe building you a custom pump and pan combo. Their stuff is very compact and relatively reasonably priced.
