4
5
Ready to Start Coyote Engine: Any Cautions?
Hi All - Exciting moment! I think I'm at a point where I can start the Coyote engine. All fluids are in. All engine, transmission, fan, and battery wiring is done. The engine temp, oil temp, and oil pressure sensors are in. The fan is ECM controlled and I have the circuit grounded. The only wiring that is not done are the gauges (SpeedHut), switches, lights, and the Russ Thompson turn signals. I've wired-up the ignition switch in a temporary MDF dashboard.
I may temporarily install the side pipes for noise reasons. I need to install the fuel pressure regulator gauge to set the pressure once it's started. Ground the fuel tank. Add fuel. Is there anything I'm overlooking?
32J
