0
Coyote EFI, Starter, and FPPDB Wiring Question
Okay, I'm going a little batty going between the Roadster manual, the Ron Francis Chassis Harness manual, the Coyote Fitment manual, and the Ford Coyote Controls Pack manual. And the phrasing in some of the instructions has me second-guessing.
My battery is mounted in the trunk, and between the seats I have the battery cut-off switch. Do I run the battery positive cable 'just' to the 250 amp fuse that comes with the Coyote EFI harness? Or, do I also run (branch) off this fuse terminal to the starter? Or, I suppose I could run the battery positive cable to the starter first, and then from the starter run another 4 AWG cable to the 250 amp terminal. See attached sketch.
Like I said, all the manuals have me turned around a bit. On p. 234 of the roadster manual, it says, "Run the battery cable forward on the right side of the transmission tunnel to the starter." Then, in the Coyote fitment manual, p. 98 says "From the other inline fuse stud run a battery cable to the starter battery cable or to a battery cut-off switch."
I'm hoping someone can clear this up for me. Thanks in advance.
32J
