Quick Update. Couldn't get in the track day this weekend because I waited too long on a weather forecast - the groups were full. There is another day the second week in March, which I signed up for. While I had the time, I fixed the broken brake line and purged the whole system - back to normal.
I had originally planned to change one thing on the dry sump system at a time, but with the extra "down time" I went ahead and changed the two -12 suction lines from the oil pan to the oil scavenge pump. These are the lines that work under vacuum, along with the oil supply line to the OEM pump. I went with AQP stainless braided hose, which is rated for vacuum. As I suspected (and thought I remembered) Chad has placed flexible stainless steel helixes in these lines to keep them from collapsing. While I believe they did keep the lines from collapsing, they certainly had a negative impact on flow. They don't take up a lot of space, but they make the inside of the tube a much more difficult flow path.
Interestingly, when I run the car in the garage, the -8 suction line heats up the fastest of the three when checked at the inlet to the pump. The -8 is at the front of the engine, is the smallest, and has the "newest" pump. All three lines are moving oil. There could be several reasons why...
1) -8 line is smaller and is a better "straw" for sucking out oil...
2) -8 line is smaller and has less mass, so heats up more quickly
3) -8 line is connected to the newest "half stage" gear pump, so it is more efficient
4) some combination of the above, or something else
The -8 line is not the shortest, so length is not the issue. In the end, I am not sure it makes any difference. The objective of getting more oil flow has been achieved. Now if I could only get my car to the track to verify. Fingers crossed.....
