KW HLS Hydraulic Lift System
Hello all!
I'm working on a GTM build, and would like to add the KW Suspension HLS Hydraulic Lift System to add ground clearance for curbs, speed bumps, etc. I've used it successfully in the past on Porsche builds and am very happy with its performance.
I've found some threads around the internet talking about different dampers for FFR GTM's, but its still unclear if I can just order their KW HLS C5/C6 kit? Should I specify a different spring rate or does anyone think the valving will be an issue?
https://www.kwsuspensions.com/produc...-19261415.html
Neel
