I've been through several threads and have tried numerous solutions, but my engine is still overheating badly. There doesn't seem to be any circulation through the radiator. I am using the 2.5 L non turbo engine, and I installed the breeze coolant lines. There are no leaks in the system, but the engine outlet line is hot and the engine inlet line remains stone cold.
Here's what I've tried so far:
1. Lift the front end and slowly burp the system to try to remove air pockets.
2. Lift the rear and repeat the process above. I have a fill /flush port in the rear line that fed the old heater core.
3. Force flush coolant through the line with the rear end raised. That should have cleared any air pockets.
4. Replaced the thermostat. Turns out both the old and new thermostats work fine in a boiling pot test.
5. Completely replaced the radiator as there could have been some blockage inside the old rad.
Does anyone have any other tricks or tests that we could try out? As I don't have a turbo overflow coolant tank, most of the posted solutions won't work for me.
Thanks in advance.
