Hello all,
Hope all is well. Would someone please direct me to the excellent post someone did about adjusting the Wilwood brake balance bar. I remember reading it but now I can't find it.
Thank you,
Hello all,
Thank you,
Mk4 Complete kit with IRS, IRS brakes, Power Steering, 302 mounts, 302 headers, TKO, 2 Rollbars, Leather seats,
vintage gauges, polished stainless sidepipes, front and rear sway bars, all cutouts.
Blueprint Engines 347 stroker; Tremec TKO 600; 3.55 IRS, 17" Bullitt wheels: 9" front 10.5" rear.
Delivered Nov. 6, 2018. First start Aug. 11, 2019. First Go-Cart Feb. 21, 2020.
This is the one I always see.. from the manufacturer: https://www.wilwood.com/PDF/DataSheets/ds252.pdf
Just 1 More thanked for this post
Just 1 More liked this post
Jeff are looking for how to adjust the bias once car is on the road?
And while we're at it, thoughts on installing a remote balance adjuster? I can't imaging how brake balancing would change much or need to change much unless you're racing?
Art Shand, Big Canoe GA
BPE 347 FI, Hydraulic Tremec TKX, Wilwood front & rear, GAS-N Headers/Touring Pipes, many functional upgrades.
I used a cockpit adjuster. It makes things really easy during initial setup. Not so much twisting a knob easier, but eliminating the need to find a safe place to pull off the road, adjust, get back on the road is very nice. It allows you to just drive a normal cruise, w/ an occassional hard stop when no one is behind you.
