Thread: KRC 91412000 for Coyote - what is the hole on the side for?
    Folsom, CA
    the hole on the bottom left pic, it's not the return line (2nd pic) -what is it for?
    Todd
    return line
    Folsom, CA
    return line
    that's what we thought as well, but the hole I'm referring to is smooth - no threads
    the return line connects to the pump which is attached to the tank
    Todd
    There is a bolt in that hole that fastens the reservoir to the pump. Pressure out the bottom, return at the top.
    Folsom, CA
    ah!! i needed to stick my finger in further LOL
    Todd
    Nov 2018
    Centennial, CO
    And just checking; you did get the ID:4 flow valve, yes? I can’t believe how sensitive the steering is even with the most restrictive valve, way better than the standard one though.
    Bradley
    Folsom, CA
    And just checking; you did get the ID:4 flow valve, yes? I can’t believe how sensitive the steering is even with the most restrictive valve, way than the standard one though.
    yes I got the KRC Power Steering KRC 25304000 Aluminium Flow Valve (6AN Male ID - 4) as recommended by MANY on here
    Todd
  8. Likes GTBradley liked this post
