Thanks Thanks:  86
Likes Likes:  614
Page 7 of 22 FirstFirst ... 5678917 ... LastLast
Results 241 to 280 of 869
Thread: Roadracer's #997 build
  1. #241
    Village Mills, Texas
    One interesting thing about sitting in seats with belts.. now I need to rethink where the switches are going to be because no way I'm reaching the dash with the belts on!! Everything needs to be a lot closer
  2. #242
    Dreamer
    Wassenaar, The Netherlands
    Maybe retractable three point belt would be better....
  3. #243
    Jul 2017
    San Diego
    I found out early on that I can't reach the emergency brake either with the belt on! Kinda dumb having to release the emergency brake before strapping in...
    I can't either. One of my biggest worries as my real brakes haven't felt 100% right. I like the 5 point so immtrying to figure out how to make a reach attachment that doesnt look terrible....
  4. #244
    I’m at work so can’t check but can’t we just put handbrake on other side by my legs? I thought chassis was symmetrical here..
  5. #245
    Dec 2019
    Austin, TX
    James - it's really coming together great! Love the seat belt mod! Might have to look into that for the roadster.
    Mark IV Complete kit delivered 7/7/20
    Blueprint 427 ordered 11/23/20
  6. #246
    Jun 2018
    North Vancouver, BC, Canada
    Maybe but I think it would be quite annoying on the right leg. Remember the footbox isn't roomy so the gas pedal can't be pushed left, too close to the brake already...
    Gen 1 '33 Hot Rod #1104
  7. #247
    Haha there’s room for it on the left (and it’s under your leg which is bent), but you still can’t reach it there either! It has to be up on center console to be useful while wearing belt.
  8. #248
    moving handbrake
    I moved the handbrake up onto the console. Seems that it'll work just fine up there, and is right where you want it. I'll shorten the cable abut a foot and tidy up the fitting to make it smaller (always seemed clumsy the factory option) - ordered some crimps and thimbles.
    The front bolt goes through steel hoop, and the rear will be reinforced when I add the aluminum angle to build the higher level of the console with glovebox and cupholders, etc. I'll just build it around the handbrake now.
    Has anyone else done this?
  9. Likes FF33rod liked this post
  10. #249
    Transmission tunnel
    I expected to hate the transmission tunnel after hearing stories of bad fitment and cramped footwells, but perhaps Gen2 'glass has improved here too - the driver's footwell is not symmetrical and has 2+ inches space to the right of the throttle pedal. Which looks perfect for me - I like my foot to rest against that wall. And it fits great against the firewall and chassis. I cut a couple inches out the width to pull the passenger side in a little too, and just leave enough to rivet to the aluminum.
    It was way too long though.. look where the pen is. This is where the hoop is and the end of the aluminum. I'll have to cut off some of this since it gets in the way of the new handbrake location. No worries though, I'm still building an aluminum console on top of all this.
  11. #250
    handbrake working in new location
    I got the crimps and thimbles to shorten the handbrake cable, and I wanted to simplify it a little so I re-tapped a 1/4-20 thread into the rod end and used an eye that I had lying in the parts bin.
    This shows old and new:
    For reference, I stripped back 13" of the outer coating on the handbrake cables, then looping it around and cut off the excess which was about 5.5".
    The rear of the handbrake does generate a fair amount of force, so I added some angle-iron to support it rather than aluminum. I wanted an angle here anyway - this will form one edge of the glovebox above it.
    Finally this shows the handbrake fully off and fully on - about half way up the range.
  12. Likes FF33rod liked this post
  13. #251
    Simi Valley, CA
    I'm liking the idea of moving the hand brake more and more. I just have to see how I can fit it in with my (planned) center console. Thanks for the inspiration! Keith HR #894
  14. #252
    Now that it’s working I’m looking forward to playing around with some cardboard today to see how it works out!
  15. #253
    CAD for the console
    I played around with some cardboard today to see if my plan/hope would work out. I wanted cupholders behind the gearstick, and the glovebox/elbow rest to still be usable with the handbrake in its new position. After mocking this up there are a few changes I'll make, but I'm happy with how it worked out.
    I threw the seat back in to see how it really feels, and I love that the handbrake is now right at hand. The gear stick and cupholders are perfect, and the elbow rest / glove box lid is now 6 inches higher and perfect height.
    One thing I'll change though - now I'm sitting here I noticed that the handbrake is still higher than the cupholders so I have a lot of room to come closer to the handbrake - see below. I'll be moving that whole wall at least and inch over towards the passenger side, giving way more room for the cupholders (and easier to fabricate).
  16. Likes 33fromSD, AJT '33 liked this post
  17. #254
    rank amateur
    Sep 2019
    Southeast PA
    I really like it up there. Much safer to actually be able to reach it! And I love the notch idea in the console.
  18. Likes RoadRacer liked this post
  19. #255
    Dreamer
    Looks a bit like my BMW Z1 centre console, except it sits closer to the drive, which makes a lot more sense, especically for hill starts...
  20. Likes AJT '33 liked this post
  21. #256
    Started on aluminum console
    I bent up some aluminum sheet to fit around handbrake and create a 'glove box', then started on making the next panel up that contains cupholders and gearstick. I bought a bunch of aluminum angle and strips to strengthen up the corners and edges - I want to be able to lean on it when I'm getting in.
  22. #257
    Jul 2020
    Nice work, RR. Looking at the brochures before I ordered my kit, the one thing that I didn't like about the car was the placement of the park brake. I had an inspiration one day at work when I found a leftover wiper motor and gearcase assembly for a caterpillar loader. I'm going to try to use it under the car to pull the cables and operate it with a rocker switch. Not sure if it will produce enough torque for the job, but it would sure help unclutter the inside of the car.
  23. Likes RoadRacer liked this post
  24. #258
    Quote Originally Posted by junglejim View Post
    Sounds a fun project - building your own estopp (think that’s what they’re called). For this car I’m trying to minimize failure points (computers, sensors etc) and keeping everything as manual as I can.. so I discounted estopp for that reason.. when I need a handbrake I REALLY need it.
  25. #259
    well that was fun
    measure thrice, cut once, right?
    I was so pleased with this new version of the console (second version of a piece I made yesterday), with returns on the sides. Turned out great even though I couldn't use the brake for any of the bends.
    Hooray! Time to stop for lunch.
    And then I realized I had bent everything upside down. So it was all just practice for..the third attempt LOL you gotta laugh.
  26. Likes j33ptj liked this post
  27. #260
    Jun 2018
    Bummer! LOL Third times the charm.
  28. Likes RoadRacer liked this post
  29. #261
    third time's a charm!
    Here's the final front version, with returns bent all around.
    Works great around the handbrake. I can make up the sides next, but I'll wait until body is on again before figuring out the front-most piece that goes up to meet the dash. I've been wiggling my fingers out in front of gear stick with belts on and I think I can reach switches on that part.
  30. Likes j33ptj, 33fromSD, JimLev liked this post
  31. #262
    Gatineau, Quebec, canada
    Nice layout, I would suggest you soften the edge as it will dig into the side of your right leg, I know, mine does and wish i had a good 1" radius on it. You will notice it cruising down the highway more than anything.
    20200622_193837.jpg Mine, similar but maybe a bit wider than yours
    Andreas
  32. #263
    Quote Originally Posted by AJT '33 View Post
    Yeah, I understand. I'm expecting that area to be built up a lot, like a big triangle will go there. But I totally get what you're saying, thanks!
  33. Likes AJT '33 liked this post
  34. #264
    Only got a few hours this afternoon in the garage - (out for fish and chips tonight at a local pub - a taste of home!) - but I made up and trial fit the worst of the side panels. I've decided to just chuck the 'glass trans tunnel and run aluminum all the way to the bulkhead. I wanted to minimize the joints, so I had to think hard about how to make the cuts and bends
    The angle of the sheet under the handbrake matches the angle of the handbrake when off.
    The large square is just there until I fit the body and can work out the angle of the sheet up to the dashboard.
  35. Likes FF33rod, 33fromSD, JimLev liked this post
  36. #265
    next part of console..
    Today I got the body back on in order to create the drivers side panel and finish off the forward part of the console, under the dash.
    I can reach switches on the left side of that upright panel, even fully strapped in, and my leg has a nice flat panel to lean against.
  37. #266
    rank amateur
    Sep 2019
    Southeast PA
    Love it!
  38. Thanks RoadRacer thanked for this post
  39. #267
    Just wiring
    Spent the time at the weekend re-wiring some stuff and tidying up.
    • Ran a new positive battery cable that was a foot longer so it could go a better route
    • Replaced my temp autostore gauges with the FFR ones, which needed different sensors fitted
    • Finished off my battery disconnect switch
    • Moved the earth lead to a side chassis member in trunk - my first choice above fuel tank interfered with body
    • Removed the heater so I could re-route parts of wiring loom
    • re-wired distributor wires so they could go through unused fittings in one of the connectors (not really sure why these two wires didn't go through a connector)
    • Replaced ignition key switch with new Jegs 11001 switch - super simple
    • Then cut the dashboard to fit gauges in a slightly different layout - the stock layout meant one of the small gauges was hidden behind the steering wheel for me.
    • Did all the lamp, ground and positive feed wiring on the gauges
    • Went back out in the evening and chose the green lighting option
    There were a couple problems.. first the oil pressure sender worked when I first fit it, but later on after all the dash work it doesn't work. No signal coming off the sensor at all.
    Also only half the lamps light up, so I'll be looking at the bulbs and checking with voltmeter later.
    I also decided to remove the Vintage Air heater controls from the cheesy plastic case, and cut them into my aluminum panel, so I bought a decal set from summit
  40. Likes FF33rod liked this post
  41. #268
    Two more weekends doing nothing but wiring - I love wiring (seriously)! I love how you can make everything neat and tidy, crimped, soldered, shrinked, tie wrapped, taped and in conduit.
    A lot of "final" (ha!) finishing on dashboard, all wired and working. Fitted the headlights which meant final fit of grill. Headlights went together easily although wiring colors have changed again - many threads here have different colors. Still, a 9v battery made it easy to figure out. I didn't want DRL, so simple wiring. Tidied up the wiring underfloor when I connected up the speedo feed and neutral switch on TKO.
    I was amazed at the headlights. In the day that silly little LED looked like nothing. But at night I opened the garage door and the lights lit up every house for 200yds. Pretty amazing. I test-wired the rear lights and they worked the first time too - again very bright LED's!
    Moved a lot of wiring around, tucked up behind the heater and worked out how to reduce the rat's nest.. some is attached to the chassis on the right out of the way (but accessible for when I add a wiper in hardtop).
    Next I finished up the steering column. I noticed some wobble in the indicator stalk (I'm not using some parts since I swapped to a quick-release setup), so I added a water pump spacer which was perfect fit, and allows me to hold the white plastic perfectly in place. I had a roller bearing in the parts bin to reduce the drag. Works a charm.
    Finally I spent som time playing with designs for the lower switch panel below the dash. Then made it up and test-fitted everything. There will be a lightning charger cable coming up under the phone, and a cigarette lighter hidden away around the passenger side. I used an offroad bicycle phone holder, since they are all aluminum and bolt-on and designed for offroad use so hopefully will work ok in this bumpy environment
    Now I can finally finish off the trans tunnel and (I think) that's the last thing before the body goes on.
  42. Likes FF33rod, sread liked this post
  43. #269
    Haslet, Texas
    Just something to think about and only my opinion (and I will preface by saying I have an Iphone)...what I have found is that with the top off on the car, the cell phone use for music control or navigation is almost impossible. Almost the only time the screen is viewable is when the sun is in front of you. There are many times my phone has shut down because of heat, but mainly the screen is just unviewable. And to be honest there are even times where the screen on my Media Player is extremely difficult to view. For the most part I can manage, but there have been a couple times sneaking in to some of these smaller towns for car shows that I have really needed the Nav (or a map) and I have actually had to stop under a bridge or pull off at a gas station to figure out where I was.
  44. Thanks RoadRacer thanked for this post
  45. #270
    Yes thanks Jamie. Mine will be a full time hardtop (bonded eventually) so hopefully better.
  46. Likes JOP33 liked this post
  47. #271
    Haven't had many hours this weekend, but I did get a chance to make up the front top and passenger sides of the tunnel. Pretty tricky shapes, but good to get out the way. I also cut out the side panel and will make that easily removable (either dzus or screws) so I can get at the wires from the side.
  48. Likes FF33rod, HVACMAN, sread liked this post
  49. #272
    Fender welt?
    hey all, what do you think of my idea of using fender welting (not sure if that's the American word) under my aluminum transmission cover, rather than silicone? My thoughts were that I could get a watertight seal using this (perhaps still silicone on one side of the welting), but make the tunnel more easily removable if needed. I'd still rivet.
    E.g. this one: Pickup Truck Fender Welting
  50. #273
    Mini panel
    Had a couple of hours this afternoon (we have Veteran's Day off) so I made the simple sloped panel under the handbrake.
  51. Likes FF33rod liked this post
  52. #274
    Jun 2020
    SoDak
    The man has skills....love all the aluminum work you're doing!!
  53. Likes RoadRacer liked this post
  54. #275
    I just wish I could weld.. would be so much cooler
  55. #276
    Jun 2020
    SoDak
    Never too late to learn..... welding isn't that bad...
  56. #277
    True.. I’ve done MIG before but I’d have to be pretty experienced to weld this .040 aluminum! Next time
  57. Likes 33fromSD liked this post
  58. #278
    Just going to say, I bet no-one has a cuter helper. My first grandchild
    And yes, this is me baby sitting
  59. Likes FF33rod, 33fromSD, j33ptj liked this post
  60. #279
    Last weekend I started putting the aluminum together, riveting and caulking. Added some aluminum flat bar around top of glove box and made it all very stiff and strong. You can use any of the aluminum to lean on when getting in/out seats.
    2020-11-22 14.41.17.jpg 2020-11-22 14.41.04.jpg 2020-11-22 14.40.10.jpg 2020-11-22 14.40.31.jpg
    Today I had a break and worked on the bodywork in the yard cos I was babysitting puppy that couldn't safely be in garage, so I cut out pedal box panels, exhaust exits and fitted taillights. Also cut back some firewall and sill 'glass to make it fit better.
  61. Likes 33fromSD, TxMike64 liked this post
  62. #280
    On the last day of the 4 days off, I managed to get the body back on and mocked up to start figuring out where this thing goes on the chassis. Hilarious really because everything moves and the only fixed point is the firewall. In the end, I decided on a spot and drilled the holes at the back for the bolts - it's officially attached!
    Now the fun really starts, apparently LOL
    Some shots for reference later.
    2020-11-29 14.58.48.jpg 2020-11-29 14.59.11.jpg 2020-11-29 14.59.27.jpg 2020-11-29 15.00.07.jpg 2020-11-29 14.59.56.jpg
  63. Likes 33fromSD, FF33rod, JimLev liked this post
