Results 1 to 10 of 10
Thread: Intake Duct Ideas
    Feb 2020
    Tucson, AZ
    Intake Duct Ideas
    I am installing a 4.6l 2V (2002 donor) in the MK4 base kit. Looking for ideas on what everyone used for intake ducts. Modifying the donor car intake doesn’t seem very robust And not a great fit. What does the complete kit use? Thanks in advance.
    May 2020
    Centerview, MO
    Funny you should ask. I just finished mine. Mine is a bit different than yours but here is what I did. The air filter will be just behind the aluminum and the front right wheel.
    E5D09328-D83E-4BA9-ACDA-E87C56AA24FC.jpg4E284064-ABDA-49B1-99D7-CDAFF2A7DE42.jpg838945EA-11D5-4F07-A035-FF09B9412CB6.jpeg
    Just FYI, there is a topic fairly recently about this same subject on the newer 4.6L engines. I think I started it. It has some of the ones you may be looking for.
    That's exactly where I went. Did this mainly to keep the aftermarket aluminum intake tube that came with the donor. Even so, I still had to cut some of it off. There were concerns about pulling in hot air from the j-pipe, but after driving in 95-100 degree heat, I didn't notice any HP issues.
    Others just get tubes to reroute up the right top fender, ending in the free space between the radiator and accessory drive.
    Alternatively, you can do this:
    https://www.ffcars.com/threads/did-s...ey-pan.246279/
    FFR9280RD MK4 base kit, 2004 Mach 1 donor, PS, PB, ABS, TC, CC, PATS, Summit heater, DIY wire diet, RT pedal/trunk/turn signal, FFR LCAs, FFR 3-link, 17x9 FR500s all around, Ford Magnetic Gray with custom Kandy Orange stripes (Ken's Custom Auto Body)
    Jun 2015
    Ancaster, Ontario
    Here is what mine looks like...
    MKIV #8740, Canadian base kit, Picked up Dec. 2015, ‘98 Cobra 4.6 l DOHC, T45 transmission, old style IRS, Art Cuesta dieted harness/Ron Francis chassis harness, go-cart July 2018.
  5. Likes Jaguar Engineer liked this post
    Albany NY
    Hi Joe,
    Will you be able to remove the air filter once the body is installed?
    Feb 2020
    Tucson, AZ
    Quote Originally Posted by Peeker View Post
    Would you have the link to that topic by chance?
    Jun 2015
    Ancaster, Ontario
    Hi Joel,
    Yes, from the engine compartment. It is bolted to the 3/4” square tube member. Nimble hands required, of course.
    Joe
    League City, Texas
    How about a "Turkey Pan"?
    I started off with the conical filter on a tube, and ran it into the passenger side wheel well. I decided to clean up the engine bay, cover up some of the 4.6L's, umm, not beautiful looks, and made an engine cover/turkey pan intake.
    Here's my intake set-up now:
    The engine is a 2001 4.6L 2V (SOHC).
    Here are a couple threads on the topic:
    https://thefactoryfiveforum.com/show...Beautification (has before and after pics)
    https://thefactoryfiveforum.com/show...8462#post48462 (shows some of the components I fabricated)
    More photos of the components can be seen in my photo album: https://thefactoryfiveforum.com/albu...umid=25&page=2
    My Saving Grace: John 3:16
    FFR6687, Graduate #39 in the Class of 2009
    The Factory Five Forum March 2012 POM
  10. #9
    Perkasie, PA
    Quote Originally Posted by Joecobr View Post
    Mine is in this location also. It's out of the way, easy to service, and the wiring fits.
    Mark IV -- 04 Mach1 Donor -- 4.6 DOHC -- TKO 600 -- 3:55 Gears -- 3 Link - Hydroboost PS & PB -- 13" PBR's Front & 11.65's Rear -- Cuesta Wiring -- Thompson Signals -- FFR Radiator, heater, wipers, and catalytic converters -- Metco DS safety loop -- Forte 7/8" front bar -- VPM 3/4" rear bar -- Champ road race pan -- Corbeau A4 Seats -- Nitto NT-05's on 17 x 9's.
  11. #10
    League City, Texas
    Jag Engineer,
    Your engine is a SOHC, not DOHC, right? I think most of the photos in this post are of DOHC (4 valves/cylinder) engines. Mine is a SOHC (2 valve/cylinder) engine. Not sure that matters.
