Thanks Thanks:  14
Likes Likes:  75
View Poll Results: How to finish the mesh panels?
Voters
58. You may not vote on this poll
  • Gloss Black
    48 82.76%
  • Unfinished Aluminum
    10 17.24%
Page 10 of 17 FirstFirst ... 89101112 ... LastLast
Results 361 to 400 of 650
Thread: mikeb75's build thread
  1. #361
    Edmonton, Alberta
    Haha, "Planes, Trains, and Automobiles" right? LOVE that movie!
    Looks like the tear down is welll underway, will you just be swapping in a used engine or a rebuilt one?
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  2. #362
    Ding, ding, ding - WINNER
    Looking at used engines, not going to say before committed. A bit gun-shy about re/building a hybrid with the 200K mile heads.
  3. #363
    Well that is backwards in order to go fwd later on. Sad to see that right after registration. Or at any other time.
  4. #364
    Bearing, Ring or Piston?
    On today’s episode of ‘Dude, your engine’s jacked!’ we try to find the point of failure on a 192K mile ‘03 EJ205.
    For our new contestants, a quick recap: during drive engine suffered huge loss of power/hesitation. There was a constant knocking sound that corresponded with engine RPM – knocking bad been intermittent before that. Also, a severe oil leak -the pan wasn’t dry, but below ‘low’ on dipstick and left a nice puddle on the garage floor.
    Saw some very fine debris in the oil recovered from the pan.
    Pulled spark plugs; a bit sooty, probably from running rich, but no evidence of oil on plug tips.
    Oil pickup and pump also had some debris in it.
    Took off oil pan and found the mother lode! Chunks and grit.
    Didn’t see any obvious damage to crank & con-rod big ends, but didn’t grab & shake them. No burnt or discolored ends.
    Looked in the heads intakes, valves are still there. Maybe a tiny bit of oil on one of the valves.
    Very little oil in the intercooler/intake pipes or throttle body.
    Quite a bit of oil on top of the block around the rear oil galley plug that had a pressure transducer installed.
    Some oil evident weeping from the rear main seal.
    Sooooo, anyone want to put down a marker before we pull the heads?
    Looks so empty... must fill with something... soon.
  5. #365
    Wayne Presley's Avatar
    Enterprise Alabama
    The bearings are gone, the copper metal flake paint job on the inside of the pan tells me that.
  6. #366
    Mike, now that we know for sure it's the bearings, will you repair or change engine?
    Also I'm looking at your empty rear end and are those all of the wire harnesses that go in the engine bay or you completely removed some?
  7. #367
    Frank, not planning on rebuilding engine; will replace.
    That's pretty much all the wiring. The signals & light portion of the harness was removed with the rear bumper cover. So there is starter, alternator, engine harness to connectors, and a few misc. sensor leads, and the GPS antenna - most everything is zip tied out of the way right now.
    Wayne, the metal flake is nice, but you should see the chunks. I thought about panning for gold... I think I'm going to have to tear it all the way down to find the failure. Oh well first time for everything -and I don't have to worry about breaking something.
  8. #368
    Still planning on the same engine specs or you might consider something different, like displ, or # of cyl, etc. Just curious to picture what you would put in next. It's sad this one died I admit! But it's also an opportunity for something new in the future.
  9. #369
    A successor has been chosen
    Dropped a bunch of coin today... but now have one of these sitting in the garage:
    A JDM EJ207 v8 with dual scroll turbo, up-pipe, down-pipe and ECU. Estimated 50K miles on the clock and looks completely unmolested (ha -until we get our hands on it).
    Can't tell you how nice it is to have a relatively clean engine without rust & corrosion on every surface. Bolts came out so nice and easy.
    Let the games commence!
  10. #370
    Denver, CO
    Nice!
  11. #371
    Nice stuff man, nice stuff! I wish I could spend my money on improvement parts that I'll have fun with, but I spend on useless parts required for regulations, so I damn hope you make that engine great and have a lot of fun with it! Why don't you do like Hammond and learn how to drift with it? (S01E13)
    What's your goal? I mean besides dropping it in, are you planning on changing something?
  12. #372
    Thanks all! Actually, we're planning to install it without major modifications.
    We will take off the oil-not-a-cooler and relocate the oil filter as the previous install had.
    The turbo & exhaust headers are not going to be changed.
    We'll keep the intake manifold & injectors as they come right now - except for the cold air intake system that was in place.
    The biggest changes were doing during this install will be a small-overhaul of the fuel system: installing a Holly HydraMat with the Walboro 255 fuel pump to avoid having to run a surge tank. The fuel lines are going to be changed out from rubber to PTFE braided with AN-6 hardware.
    The oil cooler will be replaced with a 1 size larger core (still Setrab) in the same location, but I will fix the body panel so the cooler actually gets air (inspired by Canadian818).
    The harness bar is going to be reinforced and we will make a couple of track specific additions.
    Frank, the ongoing saga of your trials to be complaint bring a tear to my eye -such a load of crap work. I thought MD was bad, but I won't complain about it again; promise!
  13. #373
    No worries Mike, tnx for the support and subscription to my temporarily dead channel. lolll
    Your list of tasks sounds interesting, many hours ahead but all good stuff and little improvements that will make the car even better. Maybe that engine blow up didn't happen for no reason.
    I might have missed the whole thing about your build, but who's "we"?
  14. #374
    Father-in-law is my partner in crime.
  15. #375
    Leesburg, VA
    Congrats on the new motor, but sorry to hear about the old one. You could probably part it out or rebuild it and have a spare. The new motor looks very nice though, good selection!
  16. #376
    Back on the Horse
    This update has been a long time coming -there has been no point on writing about disassembling the car or refreshing the motor.
    So… not quite done yet, but the ‘new’ motor is in.
    The fuel system has been overhauled – installed a HydraMat which required significant modifications to the tank, replaced or replacing the fuel lines and filter.
    The wiring has been worked over -behind the dash is moved and re-organized. Not really better, but the fuse box is now in the passenger foot well.
    The Engine & bulkhead wiring harness is cleaned up a bit and we’ve added the control wires for the intake AVCS.
    We will keep plugging away
  17. #377
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Nice work! Bet it feels good having the new motor in there now.
  18. #378
    Bend, Oregon
    Did the "new" motor come with a JDM ECU?
    Owner: Colonel Red Racing
  19. #379
    Yes. Otherwise i'd be in trouble trying to get carberry figured out.
  20. #380
    Quote Originally Posted by mikeb75 View Post
    Why? If I recall others with same tank had no issue dropping the mat inside.
  21. #381
    Rev 1 gas tank. First had a marginal opening size to get the hydramat in to the tank. Then the surge cup in the tank interfered with the hydramat lying flat.
    I put up a video on the build channel , but basically I cut open the top of the tank, cut out the surge cup, added baffles with hinged doors, installed the hydramat, added aluminum tie downs and a top plate, reassembled the pump then finally welded the tank back together. Took a few days to complete -I knew it was going to be a big (intimidating) job, but in'm glad I did it.
  22. #382
    Gen1, I got Gen1. I'm an old school like you. Awesome job you did there. No way in hell I have time or will to get the tank off, that mat will have to sit in place without any modification. I recall redfogo did without a prob but I wonder if he had gen1 or 2 tank... I thought Gen2 was worse.
  23. #383
    Easy way to fill/purge cooling system
    We figured out an easy way to fill & purge the cooling system. Remember that we are using a different radiator that does not have a front rad cap, so filling and getting all the air bubbles out of the system was a major pain - it took a few days of start/heat/stop cycles.
    So we added an inline radiator drain valve right in front of the radiator inlet.
    Now we can run a bit of hose to a fill reservoir that is placed above the highest point in the car and the system looks to happily fill and purge -left the rear expansion tank cap off and got eventually had a splash on the floor.
    Still need to run the engine and heat cycle to push the last of the trapped air through, but I'm thinking this setup will work for that as well.
    The good news is we're getting close to being able to start the new engine!
  24. #384
    Enterprise Alabama
    did you do my cooling system mod?
  25. #385
    Yup. 90 degree barb and JB weld (I like to nuke it from orbit...)
  26. #386
    Welp, this weekend was a bit disappointing...
    Was planning on first start, but rather we got to spend 2 hours tracing an electrical problem - the 80 AMP fusible link in the engine bay fuse box blew. I had shorted something when disassembling the switch console. Interesting problem: with the master power on we would get power through OBD2 to the RaceCapture and the horn, but the instrument cluster and everything else was dead. Replaced that and back in business.
    Then we got to spend the rest of the afternoon trying to figure out why no oil pressure (or any oil for that matter) when priming the system with the starter. Our first guess is the Killer-B oil pick-up isn't installed properly (I had some concerns about it but stupidly gave it a go). Headers are back off and next get to drop the oil pan... again. fun.
  27. #387
    Edmonton, Alberta
    Do EJ's build oil pressure with just the starter? Obviously my engine is a different animal but I seen no movement on my oil pressure gauge when cranking. I removed my turbo's oil feed line and confirmed she was pumping. Then on first start up I wrapped my 100psi gauge! Turns out rotaries run a fairly high pressure, lol.
    818 SRX - #91
    Arrived 01/02/2014
  28. #388
    Rotary's do build pressure with the starter, 10-14psi
    our ej builds about the same with the starter. And yes, Mazda turbo oil pump will put out stupid oil pressure at start up, we see 130psi!
  29. #389
    Yay, have oil pressure!
    Had to replace oil pickup tube - for some odd reason the Killer-B ultimate oil pickup was incompatible with this EJ207 block. There was a slight gap between the face of the pickup and the block after the bolts were snugged down... strange since this same pickup fit perfectly on the prior EJ205 block.
    Also had to replace the oil pressure transducer I added at the oil filter block. Go ebay garbage; transducer arrived dead - read 2.5 volts at 0 PSI. For now I have a 500 PSI transducer installed, which will be bad for correct resolution and scale, but at least it reads .5v at 0 PSI.
    onward.
  30. #390
    onward.
    Mike,
    Your ebay oil pressure transducer is probably good, but just put in the wrong application.
    For example. A sensor that read minus 100 to plus 100 PSI would read 2.5 volts at 0 PSI.
  31. #391
    Keep up the good work Mike, we want to see you on the road very soon and driving a for a long long trip in perfect sound harmonics.
  32. #392
    Mike,
    Was a possibility, so checked. Nope, its a 0-150 range, and voltage never varies regardless of actual pressure.
  33. #393
    Yay
    First and most important thing: thank you to everyone who makes it possible to enjoy my freedom and hobby - especially those to whom this day is dedicated.
    Second and less important thing: engine breathed fire for the first time in the 818 today -good times
    Lots of other updates are coming, but this one was a pretty major fight to get to. After fighting the oil pickup issue and the oil pressure sensor the fuel pump died. Wasn't quite sure how I was going to deal with that since I assed up the fuel tank when I assembled it, but pulling and replacing the fuel pump was a 30 minute job, almost as easy as changing out a non hacked tank one.
  34. #394
    Lol, your vids are so funny. He said "10sec" but it was 28sec.
    Re-loaded, re-first, re-start! Great thinking!
    I like the end! You turn around, re-smile and re-thumbs up!
    Well yeah! Thumbs up for the re-engine!
  35. #395
    Re-thumbs up! Fire extinguisher still full and it makes good smell. Re-Congrats.
  36. #396
    Thanks guys! Was a good day.
  37. #397
    Hindsight's Avatar
    Atlanta
    Congrats Mike!
  38. #398
    Wing!
    This car needs a rear wing -because race car!
    First step is to build the wing mount. Other builds have put together very nice pieces -we put together something simple because of limited skill level and tools available. For whatever reason, I bought 1.5” square tubing. I’m sure 1” would work just as well. We have a Harbor Freight cut-off saw and originally a Dewalt metal cut-off wheel that was crap -wasn’t flat so the blade vibrated and didn’t cut true. A second (thicker) blade solved that problem.
    With the hard top there is just enough room to situate the wing if it’s at the extreme back of the car, so within those limitations we measured, planned and said a quick prayer -then off to make some cuts.
    First, the rearmost box was 33” wide and would stand 17 ¾” over the rear most tube of the frame. Tacked it together and lined it up on the back bar. John had the good idea to use a piece of PVC to steady the box while we got measurements and checked for squareness & true.
    The upper braces are 21” and will tie in to the rear strut brace using the upper bolts. Initially we had a stack of weld on tabs, but with the 1.5” tube there would only be 2 faces to weld, a 1” and 1.5” seam. We looked at boxing the end of the tube, but then saw some hefty angle iron I had bought for another job. Perfect. We get a huge amount of overlap for weld seams and can cut to length (3”) to tie into the bolt and let the side tube rest on it.
    Cut the upper tubes to length and weld them to the back box. Last step is to add tabs to the rear bar. Those weld on tabs came in handy here and with a 1” length of angle iron we have a strong mounting bracket. The brackets were drilled and we ran lag bolts through to anchor the wing mount and still allow removal.
    I am still checking clearances, but there seems to be enough room to install a hug-jazz muffler between the transmission and vertical stay. Also, I should be able to add a rear crash bar to the outside of the wing mount at the height of the shifter linkage. Lastly, I need to relief cut the angle iron to make a cross bar about 5” in front of the back bar to complete the wing riser stays, and I’ll use this same piece to anchor the rear corners of the hard top.
    Some finish welds (heh) and paint and this job should be done!
    (timelapse of a very long day)
    https://youtu.be/09UgQ_Byp4c
  39. #399
    Preview of new look
    Very happy with how everything is looking now that we've put the hard top back on for sizing and fit. Some preview pics
  40. #400
    Another little update
    Been busy with the punch list of things to fix/finalize or rebuild, but I'm seeing the light at the end of the tunnel -actually I'm in final re-assembly with nothing major to fabricate!
    This update is to the interior treatment of the hard top. As most C builders know, the headliner assembly is a bit of a black art. There is a roll of (pretty nice actually) headliner material and an aluminum sheet that is cut to sort of fit in the raw fiberglass recess formed by the air channels.
    And as most C builders know, the aluminum panel doesn't really like to stay up with mortal glues.
    So I trashed it. Instead I bought some replacement (and not quite as nice) headliner material and a can of 3M High Strength 90 spray adhesive. The first change was fixing the ridge formed by the bonding of the plastic air channels to the inside of the hard top. My initial thought was to sand down the edge to smooth it out. After the first hour of sanding I wasn't so crazy about that idea. Never fear - I have Bondo... er Evercoat Rage Gold.
    A few applications later I had smoother transitions from the plastic to the fiberglass. Didn't need to be perfectly smooth because the headliner is foam backed. Next to glue in the headliner material.
    I covered the A and B pillars first, then the main area front to back. For my first time applying a headliner it isn't terrible... about a '6'.
    The spray adhesive is crazy strong. I peeled up one of the B pillars to try to improve the seam and it didn't come off without a major fight... and sanding... and acetone. I think it will be pretty robust for a few years.
    Then I made fill in blocks to address the gaps between the upper firewall and the windows. Again, if you're a 'C' builder, you know the black stripe on the vent windows is where the firewall sits - and you know that because these windows are mounted to the outside there is a gap between it and the firewall. A small block stuck here first wrapped in gold reflective foil because race car then the front wrapped in headliner because vain with a little gasket applique to address the curve of the glass does the trick to fill this area.
    Again, about a 6 out of 10, but much better than how it was. And everything (almost) seals up tight which is a HUGE improvement from how it was. I think some Alcantara and a bit more skill in application would really transform how the interior looks. Maybe for build phase 3...
    Oh, and spare a thought for my partner in crime. FIL may have a detaching retina -so major world of suck there. We will find out more tomorrow.
