Well, I'm getting to the end of the build, and it seems that the last few parts have been fighting me tooth and nail. Now, one that should have been pretty simple if giving me grief.
I'm running dual roll bars. Passenger side fit perfectly. The drivers side however seems to have an angle off slightly, causing an unsightly gap where the hoop and the rear support bar come (seam) together. We sanded and reamed the pipes to get a little more play to try and fit them together, which made it better, but still a noticeable gap, especially since the gap is right behind the drivers head. As you will see in the pictures, the gap is only on one side of the pipe (toward the front), and it doesn't matter how I turn the rear bar, the gap stays in the front. When I remove them from the car, they match up perfectly, so its not a "pipe fitting" problem. It would appear to be that the short angle piece coming off the main part of the bar, or the connection point in the trunk for the rear support bar might be just a hair off.
Given all the time and effort thats gone into finishing the car, I really don't want to "live" with the little gap. Has anyone else experienced this, or have any ideas on how to resolve? The easiest would be to shave the top of the bar where the gap is (back side), but with Chromed parts, that really isn't an option.
Please let me know if you have any questions. Pictures are attached.IMG_20130415_145959_781.jpgIMG_20130415_150006_005.jpgIMG_20130415_150036_309.jpg
