You can find the mounts here.
http://www.mcmaster.com/#catalog/118/1381/=j3c9c6
I got both of these..
http://www.mcmaster.com/#5823K24
http://www.mcmaster.com/#93945K37
Turns out I lied I actually used the rubber ones with the stainless stud. They are both the same durometer or hardness so there was no difference there. you really cant tell them apart unless you look at the stainless stud. The neoprene is a little more heat resistant, but I don't think they will be 300 degrees.
I love stainless steel so I used those.
Jegs has the accuseal clamps.
