Doing some "dry-fitting" on the Coupe. How does my dash-steering shaft-steering wheel location compare to yours?
Pictures or measurements would be nice - as well as how the car looked when you finished this stage. The steering shaft is closer to the passenger side, as you can see from the Factory-supplied, pre-drilled dashboard. I will either patch the ugly hole (trim ring/gasket?) or make a new plate for the front of the dash.
I will be using the "modern" Autometer gauges, which are smaller than the vintage units.
Here are some images of my setup.
Thanks.....
