SOLD
Factory Five Mark IV Roadster for sale - Richmond, VA area
SOLD
I have a new addition to the family and won't be able to complete the assembly of my kit car. I hate to see it go but family has to come first. Just about everything you need including oils are in this package. I also have an engine stand, engine hoist and some Matco tools for sale separately to help put everything together. A combo deal could be worked out to include the kit car package, tools and engine stand and hoist. (See below)
Here is what is included in this Cobra package: $29,000 negotiable
Factory Five Mark IV roadster Complete kit (retails for $19,990 by itself)
- too much to list individually, go to https://www.factoryfive.com/kits/mk4.../what-you-get/ to see everything that comes in the Complete kit
- Ford Racing 5.0 L Coyote Engine w/ flywheel (rated at 412hp / 390 ft-lb torque) Emissions legal
- Ford Racing Engine install kit (ECU, wiring harness)
- Ford Racing Tremec 6-Speed Transmission
- Hudlow Axle Custom Rear end Assembly (posi, Ford 8.8, 3.73 gears, 31 spline axles)
- Brembo Front Brake Kit (rotors, brackets, lines)
- Ford Racing rear brake kit
- Auto Xtra Ceramic disk brakes
- A1 Cardone Friction choice calipers (left & right) (18-B4824) (18-B4825) $61.95 each
- Royal Purple engine oil, transmission oil, gear oil
- Weld Wheels Forged Five Spoke Front 17 x 11, Rear 17 x 12
- Mickey Thompson Street Comp Tires - Front 245/45R17
- Mickey Thompson ET Street Radial II - Rear 315/35R17
8_Matco_JSC500_ServiceCart.jpg1_BodyFrame_Front.jpg2_BodyFrame_Rear.jpg3_PartsBoxes.jpg4_FordRacing_Engine.jpg5_Tremec_Transmission.jpg6_HudlowAxle_RearEndAssembly.jpg7_WeldForgedWheels_MickeyThompsonTires.jpg
The following items are being sold separately from the kit car package. If you wanted to buy everything together then I could do a combo deal of $33,000
Engine stand and Engine hoist from Summit Racing - sell for $250 for both
Tools for Sale: $4150 for all shown below
Matco Tool Box - Jamestown Service Cart JSC500
Matco Tools
- 12 pc Opti-Torque Pro Long Combination wrench set (SMCL122T)
- 10 pc Opti-Torque Pro Extra Long Combination Metric wrench set (SMCXLM10T)
- 3 pc Multi-Position Prybar set (IDPOSET3)
- 8 pc Screwdrivers set (SSO8C)
- 18 volt ½" Drill Driver Kit (MCL18DDKIT)
- ½" Impact Wrench (MT1769A)
- 3 pc Extra Long Needle Nose Pliers set (PNO3SB)
- 3 pc High Leverage cutting pliers set (SPDC3)
- 3 pc Alligator Pliers set (PA3S)
- 3 pc Wire striper / crimper (MST700E)
- Torque Wrench TRC150 (CG3150FTC-MTB)
- Klik Fast rivet tool HP-2 riveter (61660) not full kit (kit price $93.85)
- 3 pc ratchet set 1/4th, 3/8th, 1/2th (SRTD3T)
- 1/4th SAE socket set 9/16th -- 3/15th (SA106TB) qty 2
- 1/4th Metric socket set 6 -14 mm (SAM92TB)
- 3/8th SAE socket set 1" -- 1/4th " (SB136TA)
- 3/8th Metric socket set 19mm -- 8mm (SBM122TA)
- 3/8th Metric socket set 22mm -- 6mm (SBM176TA)
- 1" SAE socket set 1" -- 7/16th" (SC106TA)
- 1" Metric socket set 24mm -- 10mm (SCM156TA)
