0
0
I was afraid to weld to the tracks in fear of damaging the slide surface. I glued ours about 3 time and finally gave up and decided to just glass in some upper and lower mounts and let the upper and lower bolts do the holding. But these sure would have been slick.
Originally Posted by
VRaptor SpeedWorks, LLC
Hey Hugo.......your order went out yesterday morning......I did not come up with this idea until yesterday afternoon....
I'll get you taken care of. Thanks!
sk7500......I've been welding all of the FFR brackets to both the window tracks and the door frame once the window is adjusted. The adhesive they provide does not hold up in the long run (and I doubt that using the same adhesive on these with a flange would be much different....eventually it will fail). These Window Positioners are Alum......they would not weld very well to steel. ;-) The alum is much better to clamp down to the door frame and stay put than steel would be, I can cut it more accurately than the steel with virtually no clean-up needed of the parts, and I have tons of scrap pieces of .080" alum here to cut these out of......thus the cheap/virtually free price.
