I've thought for a while that the 818 would make a great candidate for a through the road hybrid system. You would power the rear wheels with a gas engine, and the front wheels with an electric motor.
There is a professor developing a hybrid retrofit system that can be added to just about any car. The target price is $3,000 after some production volume gets underway. It uses wheel hub motors, which are not ideal, but could pprobably be converted to in-board for the 818.
http://green.autoblog.com/2012/08/01...in-hybrid-kit/
One disadvantage is that the engine cannot shut off, I think, because it is still needed to run thing like the power steering and the vacuum system. If your donor engine, however is equipped with start/stop, I think you can get around that issue. The primary engine for the high mpg version, I've heard, is the Ford Ecoboost. Ford has a 1.0 liter, three cylider Ecoboost engine, with start-stop which makes 123 hp. They currently offer it in their European Focus, but it may soon come over to the US in the Fiesta.
This system might not work well for a build where performance is the only goal in mind. The extra power and AWD would be offset by the added weight. There have been a few recent victories from hybrids, but those used lighter weight, more powerful flywheel energy storage systems in lieu of batteries. It would, however, be a great idea if you want to build a fast car that also gets good mpg.
