Likes Likes:  2
Results 1 to 8 of 8
Thread: Need Wide Band A/F Gauge Advice
    Nov 2023
    Upstate South Carolina
    I'm running a 427W with Holley 750 double pumper. I wanted a "stand alone" air/fuel meter to aid with tuning. I installed an analog-style (NOS brand) meter along with a Bosch LSU 4.9 O2 sensor which came with the kit. I am NOT impressed with the gauge. (Yes, it is installed correctly). It works sometimes....but not other times. Sometimes, under a steady load, rpm, and throttle position the needle will jump around quite a bit (for example, from back and forth from 13.0 to 19.0 rapidly).
    1) I've decided I want to change out the gauge and I am looking for recommendations for a better gauge. I would prefer analog style if possible as I find it easier to read at a glance while driving.
    2) I'm wondering about the plug connection for the Bosch 4.9 sensor. My question is: Is this connection a universal connection? If so, I would only need to buy a gauge and plug it in the the sensor I already have. This would lower my cost as I would not have to buy a complete kit. For some reason, I am thinking all Bosch 4.9 sensors have the same plug.
    Thanks for any help.
    Jun 2020
    Rising Sun , Md.
    I too have the same engine set up as you do. I used a AEM afr gauge which gives both analog and digital read out.afr gauge.png I like its operation for tuning.
    FFR 9883 MKIV ,427 Windsor engine
    TKX 5 speed, Three Link 3.55 gears
    Power Steering, Leather Seats
    18" Wheels and Tires, Drop Trunk
    Fun Package
  3. Likes ProfessorB liked this post
    Oct 2022
    FWIW, Engine Masters did a comparison of A/F gauges from the cheapest they could find to the most expensive and they all read the same.
    Jun 2020
    The 4.9 sensors seem to all have the standard plug. The older 4.2 came in several different types. A good source for understanding the various bosch O2 sensors and their wiring is here:
    https://www.wbo2.com/cable/lsuconns.htm
    Nov 2023
    Just ordered one yesterday. Should be here today. I'll report any findings when I have them.
  7. Thanks ProfessorB thanked for this post
  8. #6
    Nov 2023
    Quote Originally Posted by Dgc333 View Post
    Yeah, I'm familiar with the findings of the gauge comparison , which is why I bought a cheap gauge (NOS kit was only $200 with a Bosch 4.9 sensor). They didn't mention the NOS specifically and it just isn't working well.
  9. #7
    Nov 2023
    Quote Originally Posted by Wizbangdoodle View Post
    I'm curious about which one you ordered?
  10. #8
    I'm looking at this one. BT and goes to your phone.
    https://pe-ltd.com/product/wideband/
