Quote Originally Posted by ToeKneeNose View Post
Thanks for pointing me there Jim. I had been looking at the summary table at the beginning but not the rest of the comments from the 335 R18 perspective. Looks like you have some direct experience.
My take away is that 335 R18 will work. I just need to figure out the correct backspacing to get the proper fender fitment now and hopefully reduce the the tube trimming, if needed.
I plugged in shakey's rear wheel/tire combo and my intended combo to willitfit and essectially what I was expecting.
I guess my final question is do the people running these 325/30 R19 wheels have an extra 10mm of clearance between the fender and the outer sidewall?
My guess is that you would still have some rubbing issues with the frame. Nothing that you can't fix though. Also depends on what ride height you want, I am at 4 inches all the way around which is a little higher than most. I would also say that my tires are right at edge of the rear fender in width and no issues rubbing on the body. I think a 335 would stick out just a hair. Have you seen Rsnake's build on youtube? I think his first set of tires were 335/30r18 and he talks about his clearance issues and running spacers. https://www.youtube.com/@cobradaytonabuild1671
Hope that helps,
Shakey
