6
13
CW_MI
I used the 76 series in my Mk5 build with banjo fittings. I had to grind some off the top of the banjo bolt, and notched the frame. I later found i could have used a different 7/8 fitting that might have elieveated the need to grind the frame.
I used a 13/16 for the front, and a 7/8 for the rear, Wilwood brakes from FFR.
Hi. I’m on this step and the clearance isn’t enough for the larger banjo bolt.
Which banjo bolt did you think would have fit better? I don’t want to notch the frame.
Current: Building a Mk5 2/ Borowski 427 CI + Jim Inglese Stacks + TKX
Previous: Ultima RS #141 w/ LT4 Dry Sump + G96.01 + AP Racing Brakes + AiM -
https://www.ultima141.com
