Thanks Thanks:  77
Likes Likes:  148
Page 12 of 12 FirstFirst ... 2101112
Results 441 to 463 of 463
Thread: Angelina: Build Story of my 4-wheeled Motorcycle
  1. #441
    Sep 2022
    Thanks Jesse! I may reach out to you about your spoiler design
    Craig C
  2. Likes Blitzboy54 liked this post
  3. #442
    Sep 2022
    Miscellaneous plumbing tidying up
    Hey Y'All,
    After looking at my coolant overflow hose routing some more, I wanted to make it look more presentable
    The surprise was that the overflow port from the filler neck was actually 1/16" NPT...kinda surprising how small it is...
    So I got some fittings and tried them out. Here's what I decided on:
    I was happy with the distance to the upper radiator hose, so I routed the new overflow hose right next to it and held it in place with a couple of zip-ties. I like this routing much better than before
    The expansion/overflow tank's overflow hose got routed in front (and out of the way). Here, I zip-tied it to the unused sway bar bolt hole
    Then, I put the "sight tube" back on the other side of the tank, and it is easier to see the level now...and the fittings are working well
    Lastly, to prepare for my flush-n-fill of the Evans waterless coolant, I added the warning stickers to the fill caps
    And finally, since I can trust the Pro-Flo4 fuel pressure reading, I removed the mechanical fuel pressure gauge from the pressure regulator and plugged it with a fitting.
    Until next post, Happy Building!
    Craig C
  4. #443
    Sep 2022
    Mounting the seat frames to the inclined Breeze mounts
    Hey Y'All,
    As a follow-up to an earlier post about checking the pedal ergonomics, I wanted to get some preliminary stuff out-of-the-way towards that goal. This weekend, I spent some time getting the Breeze inclined seat mount kit assembled...
    The biggest stress was to NOT mess-up the seat upholstery by accidentally drilling thru it Measure and center carefully, then get some backing material in-place, and it goes pretty well per the instructions...
    holes drilled into the FFR seat frames:
    bolted onto the inclined mounts:
    Then: install the fiber-board seat pan. This required more modification from the as-delivered materials.
    Mod1: the pre-drilled holes did not line-up with my seat frame rails...so, I just flipped them around and located/drilled my own
    Mod2: then I couldn't get the seat bottom cushion re-installed on (to my liking) with the new seat pan in place, so I trimmed 1/2" off the front to make it stick out only 3" from the front-most frame tube. This allowed me to fit the bottom cushion better without fear of tearing something. It still seems "taught" enough for eventual stretching and relaxing of the upholstery, so all good!
    Note: the inclined mounts are not drilled/riveted for final installation -- this is just a sanity check of the "likely" position to check for overall ergonomics. I'll locate/rivet the inclined mounts after the body is on...
    Since I'm just checking the ergonomics, here's a check to see how well I can get the controls aligned with the shoulder harness locations
    Feels pretty good!
    Until next time, Happy Building!
    Craig C
  5. #444
    Sep 2022
    Adjusting the clutch pedal
    Hey Y'All,
    Not much progress this week for me since I had more important affairs to attend to...but I did manage to take as much "slack" out of my Forte' hydraulic clutch system as possible (by adjusting the pushrod at the slave cylinder for 3/16" per recommendation from Mike) and then trimming my own clutch pedal stop to maximize the travel while keeping the overall ergonomics reasonable.
    First picture though is the Wilwood clutch pedal pad trimmed down to give me more room laterally for my foot on the "dead" pedal that I'll be making soon
    Next picture is of my clutch pedal stop that I trimmed up a little to get me more overall clutch pedal travel
    Then, I maximized the effective "stroke" of the clutch pedal by backing out the adjuster at the top pivot point (pushrod adjuster) as I experimented with clutch engagement in 1st and reverse gears as the engine was running
    This was the compromise height. I'd like it to be a bit lower, but this wasn't bad while "driving" the car in the garage...
    Here's another view of the overall arrangement
    Now that the clutch pedal height is reasonably set, I hope to make my new "dead" pedal and mount it to the footbox panel...I'll try to do that this week
    Until then, Happy Building!
    Craig C
  6. Thanks RobHartley thanked for this post
  7. #445
    Sep 2024
    Bismarck, ND
    Great work!
    I have the Forte clutch slave cylinder set up as well and I'm at this part. How did you "test the slack" in the hydraulic system to 3/16"? Just get under the car and try manually move the clutch fork back and forth? Where are you measuring the 3/16" Thanks again
    MK4 Roadster, Delivered 12/19/24. SBF 363, TKX 0.81, IRS 3.31, PS, Hydroboost brakes, wilwood brakes, British Racing Green with Tan saddle leather interior
  8. Thanks cc2Arider thanked for this post
  9. #446
    Sep 2022
    Quote Originally Posted by Highplainsdakota View Post
    Great work!
    I called Mike on this exact topic because his slave cylinder has an anti-rattle spring inside. This serves the intended purpose...but more importantly to you & I, makes the measurement a little more challenging because you have to manually push back the piston/rod assembly back into the cylinder until it seats. It doesn't take much effort, but it has to be done. If your master cylinder piston is truly at-rest (seated) then you should be able to do this without having to crack the bleeder open. Then just find a reference point for your measurements and allow the anti-rattle spring to push the rod assembly towards the clutch pressure plate until it makes contact. That is your 3/16" goal.
    Thanks for watching my thread! Hope this helps
    Craig C
  10. Thanks RobHartley, Highplainsdakota thanked for this post
    Likes Highplainsdakota liked this post
  11. #447
    Jun 2025
    Vancouver BC
    Quote Originally Posted by cc2Arider View Post
    Craig C
    Thanks for this Craig, I am a ways away from this stage, but have book marked these clutch adjustment posts for later use and I have Mike Forte's hydraulic clutch as well
  12. Thanks cc2Arider thanked for this post
  13. #448
    Sep 2022
    Figuring out my Dead Pedal design and mounting options
    Hey Y'All,
    I've been "noodling" on my Dead Pedal design and mounting options for several weeks now. The things that worry me are:
    1) making sure I can install/remove the pedal without having to remove the body
    2) building it "solid" enough to not move or flex in normal driving
    3) not adding hardware on the outer side of the Driver's footbox panel since I don't know right now how much room I have. Ideally, I'd like to use some riv-bolts...but they protrude about 3/8" on the "blind side"...I'm not sure there is that much gap to the body
    4) making sure I think about adjustment since I'm just trial-fitting it in the garage and not actually driving the car yet...
    Here's my initial plan: fasten with "very high strength" adhesive-backed stick-on 1/4-20 x 3/4" bolts, and drill multiple mounting holes in the Al 90deg stock to provide fore-aft adjustment. I'm gonna try with a piece of 2x4x1/8" Al 90deg angle stock. With a spacing between the bolts of 1.125", I'll get 7 distinct adjustment positions spanning 2.25" for 3/8" separated holes
    Since my plan doesn't super-impose pedal mounting hardware with the existing rivet holes for my outer-panel "kickout" or "wedge", I finally rivetted the brackets. Here, I used 1/8" multi-grip SS since they "squish" so nicely. Looks good on the "blind" side, too
    Then, another mockup
    I'm glad I tried the mockup again. I didn't notice the slight "twist" in the panel once those "wedge" brackets were in-place. This means I'll need to use some spacers to account for the panel twist, or try something else. I'll have to think on this some more...
    Craig C
  14. #449
    Sep 2022
    Thinking about how I'm gonna carpet the trunk sides
    Hey Y'All,
    Since I need a break from thinking about my Dead Pedal design, I thought I'd dig into something else on my mind lately: how to carpet the upper trunk sides without needing to get creative around the frame tubes
    I originally planned to make some extra panels like the older FFR builds had...then just decided that it needed some foam "inserts" instead. This approach would also somewhat protect those existing side/front panels from damage if trunk items moved about under aggressive maneuvers...
    I'm gonna try some film-covered polystyrene 3/4" thick foam pieces. I haven't figured out how to glue them yet, but contact cement is not an option for the sides since they need to be slid into place.
    But first, I finally installed the cockpit back panel! I forgot how fast you need to work to final-rivet such a large panel before the silicone "skins" over...but no problems. I certainly made it more difficult since I used both black and silver silicone (black for frame contact / silver for panel-to-panel contact)
    Here's some initial fitting of the front panel and the lower "triangle" pieces for the sides
    mocking up foam cutouts for the spaces between frame tubes in the trunk panels.jpg
    I'll test-glue some scrap with clear Silicone this afternoon...then destruct test tomorrow
    Craig C
  15. #450
    Sep 2022
    Decided on EPS foam adhesive and glued foam to upper trunk front & side panels
    Hey Y'All,
    I tested to breakage the clear silicone (when used as an EPS foam adhesive) and while it was OK, I wanted something a little stronger. I bought some EPS-specific spray adhesive by 3M, but got nervous about the chemicals in the shop air, so I decided to use that later...perhaps the bond between the carpet and the foam would still be a good choice. For now though, I decided to adhere the EPS foam to the upper trunk front & side panels with a urethane caulk-type adhesive, since I could take advantage of the tight fit within the spaces of the frame tubes to help hold it in-place, too.
    With the plan in-place, here's how it went in:
    prepped the panels(cleaned the panels and then caulked the cockpit back panel against the main cross frame tube)
    front foam installed
    since the front foam is at an angle that might cause movement while the adhesive cures, here's a simple clamp to hold them in-place
    simple clamp to hold trunk front panel foam into place while adhesive cures.jpg
    Then cut-out and prepped the side panel foam pieces and glued them into place
    This now gives me a simpler "canvas" to apply the trunk carpet Of course, I'll still need to put down some thermal/sound padding, but that can wait for another time...
    Craig C
  16. #451
    Sep 2022
    Inner lap belt bolt assembly (revisited)
    Hey Y'All,
    Time for another mini-project: revisiting the bolt assembly design for the inner lap belts...
    Some time ago, I posted about my design intention for the inner lap belt bolts. I didn't want to "pinch" the tunnel side panels into the belt mounting tabs, so I found some angled shims on the McMaster-Carr website. All was good until I decided to emulate Paul's seatbelt choice from his earlier builds. I liked that the Schroth belts had a "street" option which includes a visible red release button that an EMT could quickly figure out (in case I was in a wreck and incapacitated ). Seem to be nice quality pieces. They have the lap belts attached to their own bolt-bracket design, which unfortunately uses 7/16" bolt holes instead of 1/2".
    This caused me to have to revisit my approach. I went back to McMaster-Carr and found some bronze bushings that were meant for 7/16" shafts. The outer diameter was 5/8" though...which meant I needed to "hog out" the transmission tunnel side panels...
    Here's the tool setup I decided on (cordless drill with burr bit slightly larger than the shaft diameter)
    plan for hogging out the inner lap belt mounting holes thru the trans side panels.jpg
    I simply held the shaft as true as possible to the mounting tab hole and made sure the "burr" was cutting the panel and not the mounting tab. The result, a reasonably-finished hole that accepted the 5/8" diameter bronze bushing
    Here's the "new" assembly
    and here's what it looks like put together
    Essentially, the bushing holds the angled shims concentric with the panel hole and ultimately, to the mounting tab hole I'm pretty sure it is strong enough for the clamping load with the recommended 7/16" bolt torque values provided by Schroth...
    Here's the assembly installed (cockpit view)
    and inside trans tunnel view
    That's all for me this weekend. I managed to get out on a Spring M/C ride for about an hour and returned refreshed!
    Craig C
  17. #452
    Sep 2022
    Final Dead Pedal design & strategy
    Hey Y'All,
    I thought enough about my Dead Pedal design and strategy to get moving on it again...
    Instead of fastening to the side of the footbox panel where it "kicked out", I simply moved the mounting location more forward to take advantage of the extra room there for riv-nuts (so that there is no interference with the body mounting). I didn't move the fastener location that far, though -- just to the area closest to the kick-out panel bracket. This way I could take advantage of the strength that the 3D shape permits. The "angle" of this panel bracket worked out well for my ergonomics, too...almost like FFR knew what they designed it for ... silly me
    Anyway, here's where I took advantage of the existing rivet locations
    and then this confirms that there is still clearance to the body (when installed)
    Now, the not-so-good-news: I won't be able to unfasten the top-most bracket mounting screw (if I ever needed to do so after the footbox and body are installed). It is too close to the outer curved footbox frame tube...difficult to get a wrench in there. So...In order to accommodate different pedal heights, I'll just add spacers to the pedal "pad" screw locations
    Here's a mockup
    This bracket, by itself, could have been "enough", but I wanted a "little extra", so I repurposed the Accel pedal pad and intend to make this a part of the design...I'll just have to get another one from Breeze
    Here's the final bracket design. I'll get this powder-coated black
    and then a final-check fit
    I'm pretty happy with the results, but I would've liked the ability to take it apart easier after final assembly...oh well...
    Until next time,
    Happy Building!
    Craig C
  18. Likes F500guy liked this post
  19. #453
    Sep 2022
    A simple change of fasteners makes the difference!
    Hey Y'All,
    I just couldn't stand that my implementation of a Dead Pedal wasn't "serviceable"...so I finally had an epiphany! Change the fasteners...Duh
    I chose serrated flange heads for the bracket to panel. Now I can get a small wrench in there even when the panel is riveted together
    Then, I chose "stand-offs" so that I only have to loosen the Torx screws on the front-side of the pads to remove or adjust the installed height Side-benefit, the flat-head design on the back-side also allows for more room near the curved frame tube ...
    See pictures below
    dead pedal bracket fastener change.jpg dead pedal bracket fastener change2.jpg dead pedal bracket fastener change3.jpg
    I'm REALLY happy how this turned out! And, I checked the ergonomics again...feels good
    Until next time, Happy Building...
    Craig C
  20. #454
    Sep 2022
    Matched set of pedal pads!
    Hey Y'All,
    A quick order from Breeze and Mark hooked me up with another pedal pad. I have a "matched" set now
    All that's left in there is to get the brackets-n-things powder-coated and start on the thermal lining and carpet install...although I may start in the trunk area initially since it is easily accessible and I'm sure to make some mistakes
    Craig C
  21. #455
    Sep 2022
    Cutting the trans top panel to make room for shifter
    Hey Y'All,
    I got motivated to finally cut out the hole for the shifter in the trans top panel after reading a recent post by Brew...
    Here's the rough cut
    followed by a confirmation measurement of the trim ring location so that I could mark/drill the holes for that
    then I added the low-profile riv-nuts and oval head fasteners to lock it into place
    which allowed me to get a final outline to trim up the hole better for the final upholstery work...which will occur later
    The trans tunnel top panel will be covered in one piece of foam-backed leather. If I'm feeling "frisky", I might consider adding a French seam along the sides with red thread...but that decision is much later. The shifter and hand brake will get their own leather "boots" sewn together longitudinally and fastened under the trim ring
    It's slowly coming together!
    Craig C
  22. #456
    Sep 2022
    Trans top panel fastener strategy
    Hey Y'All,
    Very early in my build, I got inspired by creative minds on this very Forum. One inspiration was a way to access the transmission, driveshaft, and hand brake cables from the top-side. Another was to "hide" the fasteners for the trans top panel ... not really that important, but I thought it was a nice touch...so I came up with my own design
    First, I needed a way to get to the driveshaft and hand-brake cables-n-things, so I made the back-angled piece to be pivoting along the back panel.
    Here's the back angled panel fastener strategy
    This allowed me to fasten the rear-part of the trans top panel to that small pivoting panel...which meant I still needed a way to fasten the front-part of the trans top panel. The key for me was deciding that I wanted a center console. This permitted a mechanism to hold the front part of the top panel down without any obvious fasteners at work -- I just need to do a good job fitting the foam-backed leather properly. It will be a friction fit up front
    Here's how it is all supposed to work. I tried it with the Driver's seat in-place anyway
    Step1: move the shifter and handbrake levers back for more room to maneuver...
    Step2: unfasten the rear hinged panel and lift out-of-the-way
    Step3: slide back the top panel and then rotate to clear the center console (without removing the handbrake or shifter)
    Step4: lift up and out
    I hope this inspires you to add your own creative/useful touches to your builds...Until next time, Happy Building!
    Craig C
  23. #457
    Sep 2024
    Spencerport, NY - near Rochester
    Really nice work Craig. Like the way you tied the trim ring on the tunnel to what you did with the dash.
    Pat
    MK4 complete kit Nov 2024, Blueprint 347, TKX, Hyd clutch, IRS, 3.55, touring shocks, 17" wheels, 11.65 brakes, Build Thread
  24. Thanks cc2Arider thanked for this post
  25. #458
    Sep 2022
    Quote Originally Posted by PMD24 View Post
    Pat
    Thanks Pat for the kind words and encouragement
    Craig C
  26. #459
    Sep 2022
    misc upholstery prep
    Hey Y'All,
    After getting some parts ready for the Powder Coater, I didn't get much else "significant" done on my build this weekend
    "Slow-n-steady" progress being made, though. This post shows some miscellaneous upholstery prep that most of you have done...
    First up: adding self-adhesive thermal padding to my drop trunk
    Then, I focused on the trans tunnel top panel...with top and bottom prepped
    Bottom-side got an aluminized fiberglass self-adhesive pad
    Top-side got a self-adhesive 1/8" thick closed-cell foam pad
    and lastly, I ran out of time, but did manage to start on a template for the upper trunk floor
    I'm hoping I can use this for both the thermal pad and the carpeting
    Craig C
  27. #460
    Sep 2022
    Wrapping the console with upholstery leather - part1
    Hey Y'All,
    This past weekend I spent prepping to wrap my console panel with leather...
    First up, prepping the console metal and 1/16" thick closed-cell foam for Weldwood "landau top" spray adhesive, then adhering them together
    Then trimming out the shape before the second layer of foam goes on
    next, prepping for the second layer of adhesive and foam
    then, I trimmed up the second layer of foam to get ready for the leather itself
    and finally glued the leather to the outside of the console
    Next post: part 2
    Craig C
  28. #461
    Sep 2022
    Wrapping the console with upholstery leather - part2
    Hey Y'All,
    I follow-up in this second post about wrapping my center console with upholstery leather...
    Now the hard part -- purposefully trimming the edges to wrap around all the mounting flanges
    This was the way I chose to do it...you may choose a different way...
    I made a template of 45 deg and 60deg flange corners to work out the geometry and feel comfortable knowing why I needed to cut the profile properly...then I simply folded the leather over the flanges to get the actual first-level of angles involved
    Here's the first flange trimmed
    then a second example of the prep needed for trimming the leather for another flange
    then spending the rest of the afternoon repeating this process, I got done trimming the whole thing Whew -- that was a lot of work!!
    the whole thing kinda looks like a sea urchin with all the spikes and protuberances
    Hopefully, it will be worth it in the fitment and gluing that I'll do this coming week (in part 3)...then I'll have to make a pattern for the inside layer and repeat the process...it won't be as complicated, though!
    Until next time,
    Happy Building!
    Craig C
  29. #462
    Sep 2022
    Wrapping the console with upholstery leather - part3
    Hey Y'All,
    This Weekend I spent working on my Console leather some more. I chose to work on gluing the leather onto the mounting flange inside surfaces in pairs so that I could control what I was doing better. I also used a big-box-store small container of Weldwood with a built-in brush for each of the flanges instead of spraying the glue. This meant it took me the better part of the Weekend to finish...details, details!
    Here's a picture of the flanges wrapped on the inside with leather
    Then I made sure the leather covering all the screw holes was reamed out, and checked the fit onto the car again -- tight fit, but still fits
    I'll still need to wrap the inside of the Console with leather (which means cutting, folding, and gluing the material back behind the panel opening first) and eventually condition it...but that'll wait for next Weekend (when the adhesive fully cures...I hope)
    Craig C
  30. #463
    Sep 2022
    Finishing the thermal padding in the trunk
    Hey Y'All,
    While I was literally waiting for glue to dry, I worked on finishing up the thermal pad installation in the trunk. I chose to only cover the floor...and I wanted to practice my technique on the large or awkward pieces, too, before working in the Cockpit.
    Anyway, here's my template for a really large piece for the upper trunk floor...really only critical to locate the roll bar areas, but the overall piece is trapezoidal-shaped...so there's that.
    Then after deliberating on how to wrangle such a large piece in without it shifting or bunching, installed
    I attempted to split the adhesive backing down the centerline and adhere the middle part...smoothing out towards the sides. Then I folded the back vertical edge down.
    Lastly, I fitted several smaller pieces for the lower trunk floor and covered the flat and outside edge seams with aluminized tape. Here it is finished
    Craig C
  31. Likes F500guy, RobHartley liked this post
