Originally Posted by
michael everson
The shifter trim ring hole and patch panel hole are the same size. Did you check your pack list? I thought it was in the same box as the headlights etc.
Thanks Mike. I have checked my inventory, three times so far. I will look at the box with the headlights. There is a line item that says "shifter handle components" so maybe that is it.
