Results 1 to 5 of 5
Thread: Shifter Trim Ring - Found!
    Nov 2020
    Damascus OR USA
    I had it in my head the kit came with a shifter boot and trim ring but for the life of me, I can't find them in my inventory or boxes. Box 6 has the straight shaft billet shifter and knob but that's it.
    The reason behind the question is twofold. I bought a blank transmission cover from Brent at Snakebite. While I was measuring and laying out the hole for the shifter it occurred to me that I should double check the hole size against the ring, which I can't find. Now I am thinking if I have to buy one, which is OK, I want it in hand so I can ensure the hole is correctly sized.
    It seems to me the hole in the F5 cover is a little oversized, at least for the T56 which has relatively short throws. Either way, I am curious if there is a ring floating around or if this is intentional to allow builders to adjust accordingly. I just thought it was a little odd since they provide a ring for the e-brake.
    Build 1 - 1969 Camaro Build Thread Here: https://www.camaros.net/threads/tims...y-getter.45926
    Build 2 - 1965 Daytona Coupe # 620 Build Thread Here: https://thefactoryfiveforum.com/show...-Type-65-Build
    The shifter trim ring hole and patch panel hole are the same size. Did you check your pack list? I thought it was in the same box as the headlights etc.
    Nov 2020
    Damascus OR USA
    Thanks Mike. I have checked my inventory, three times so far. I will look at the box with the headlights. There is a line item that says "shifter handle components" so maybe that is it.
    that is it.
  5. Thanks PNWTim thanked for this post
    Likes PNWTim liked this post
    Tim,
    For what it's worth, I used a 4" hole saw to cut the opening and that is just slightly smaller than the inside of the trim ring. I also installed nut seats so I can install and remove the ring with the drive train in the car.
