Quote Originally Posted by msbrown6 View Post
Having a little trouble with the clevis on the parking brake. When installed, it sits too close to the coil spring/shock absorber assembly. Any ideas? Thanks all!
Switch to a rounded head screw, turn it around so the head is on the inside, make sure the attachment clevis is oriented away from the coilover. Your alignment could be affecting this too. If the camber is way off it could make it closer. The final result is close but it fits without interference. Picture here from my Mk5 build.
