Results 1 to 3 of 3
Thread: Turn signal mounting to Vinyl Dash
    NY
    Mounting the 427ie turn signal to the vinyl dash, the backing plate does not lay flat due to the opening being molded, did you all just shave it flat ?
    Nov 2016
    "The i.e." SoCal
    Quote Originally Posted by bil1024 View Post
    I believe I covered this in one of our videos. Regardless, the back of the dash needs to be flat. You can cut it or grind it flat. We've had many installed on the plastic padded dash. Reach out to me through email if you have any questions and I'll do my best to get you back on track.
    NY
    Quote Originally Posted by i.e.427 View Post
    Thanks Frank, video helped alot got it installed
