13
63
I mostly finished my high mount brake/backup light combo. I originally wanted something functional that could be removed if needed, non permanent and still look decent. Well, I hit functional and can be removed...Final product did not really meet my cool factor. I will leave it on for now and maybe think of something different or just jet the small lights that Breeze has and forget about the back up part. There is still time to look at something else before I get the body worked over.
I started with some Oznium LED's the small 5mm ones, a piece of carbon fiber and a fire extinguisher holder from H3R I drilled and tapped the fire extinguisher holder and made a small plate from some carbon fiber that I had. I then installed and wired 2 white LED's for Back up and 4 red Brake light leds for each side. Works great, thinking of getting one of those "flash your brake lights" controller some real annoying fun. Any way, done but not super excited with the results, concept was way cooler.
Picture with both BU and Brake.jpgPicture with Brakes.jpgPlain Picture Installed.jpg
I also mounted a RAM mount for my phone, pretty functional low key thing.
Now I am ready for some spring cruising!
