Ok Gents,
I have reached the point of throwing a tantrum in my shop so I need help. First I tried putting the supplied Engine Oil pressure sensor (Platinum Gauges) in my BP 347 and the sensor is two large to allow me to thread it in, not the male portion but the actual sensor is too big and hit the block before I can get the threads in.....What should I replace it with?
Secondly where do the remaining wires go....I got the EFI harness hooked up pretty straight forwards, but what am I plugging into the.....
ELEC Send Unit harness
1. Water temp sensor? I am assuming the blue water temp wire?
2. Oil Pressure sensor? Same thing the Grey oil pressure wire?
3. All the grounds in this bundle what should I do with them as the directions state the threaded sensor is the ground?
4. Elec choke wire beige where does this go?
EFI Crank Bundle (not from blue print but the one that cam with the RF harness)
1. I connected the orange wire correctly to the coil
2. The purple TACH wire should that connect to the grey wire that is not connected to anything on the front of the engine below the distributer?
3. Speed sensor wires Green, Grey, what should these hook up to?
I would post pictures to make this much easier but that has stopped working all together and I don't need my blood pressure to go up any more.
Appreciate any help from you fine gentlemen.
