Thanks guys! Good suggestions.
I like the idea of using a cold chisel to secure the bolt head inside the bracket, and using two standard nuts on top to avoid having to crank down the friction nut so many turns while engaging the chisel :-)
I shouldn't say this, but the rest of the 3-link install looks like it will bolt up pretty readily, so I can then move onto power steering.
Brian
