So I'm in the process of getting a harness installed, and discovered that the rear bolt/nut to remove the seat from the slider track have a hex key head that's inaccessible, which means theres no way to get the nyloc nut off. Am I missing something or am I going to have to cut a slot in the bolt?
Here's the bolt in question -
Thanks in advance for the sanity check!
. Ended up cutting a slot in the bolt and that worked well enough to remove the nyloc the rest of the way.
