Results 1 to 4 of 4
Thread: NJ builders - engine donor question
    Apr 2025
    West Long Branch, NJ
    Question NJ builders - engine donor question
    Hey guys,
    I'm building my 289 roadster using a 289 block from a '68 Mustang. If you've been down this path then you know that you must be the titled owner of the car from which the engine came in order for the engine to be used, i.e. successfully title the roadster. Apparently NJ (and a number of other states) do this to ensure that the engine isn't stolen, which I believe was an issue years ago.
    So, my original plan was to keep the Mustang body until the roadster was titled, but now I'm wondering if that's even necessary. As long as the Mustang is in my name, and I have photos of the car and stuff like that, I should be able to let the car go. I realize that I can't junk the Mustang body (as the scrapyard will want the title) but if I give the car away without title as a parts donor I'm thinking that would work. It seems most "inexpensive" 60s Fords are sold for parts sans title, so this seems like a reasonable approach. And I'd prefer to not have to keep the Mustang shell in my driveway until the roadster is done
    Any thoughts? If you've been down this path, what did you do?
    Thanks!
    Rob
    289 FIA roadster (in-progress) received 11/2025
    331 SBF/Pro-Flow4 port injection/Edelbrock E-street heads/Howards hydraulic roller cam
    TKX w/.81 OD and mid-shift
    8.8" rear w/3.55 gears and three-link
    289 FIA pin drive wheels
    Aug 2023
    Rochester NY
    Not sure if same but in NY they also want to ensure engine is not stolen but there is another way. I purchased a 302 out of an old T-bird at a salvage yard. Salvage yard owned complete car and I just purchased the guaranteed to run engine. Receipt showed car VIN.
    MK4 Roadster started February 2024, Complete April 2025
    Blue, silver/black stripes, BP347sniper2, TKX, IRS, under car exhaust
    Build Thread https://thefactoryfiveforum.com/show...ild-Kit-207937
    O'Fallon, MO
    It makes no difference what people here tell you, only what the state tells you. Go ask them what to do
    Wondering if 1968 Mustang is restorable, the 289 might be more valuable there and roadster gets a crate engine. Worth considering.
    358 SBC, Winters QC, Sweet mfg, Coleman, AP Racing, ARS, TKO 600, Fuel Safe
