Thread: Return fuel feed
    Jan 2019
    Mead Colorado
    Return fuel feed
    Gents,
    I haven’t had much time to work on the roadster lately but today I was in the shop for a bit. I have a new scope so I thought I would take a look in the gas tank to see how much fuel was left (verifying the fuel gauge). I noticed my return feed hose is dumping right into the Fuel pick up “pan”. That feels like it should not be doing that. Is that correct? I can likely move it fairly easily by using a long grappler, but thought I should check. Or perhaps it doesn’t really matter.
    Thoughts?
    Mk4 complete kit arrived 10 May 23
    Current BOM and Build Thread
    Houston, TX
    It should be outside the pick-up pan if possible. Helps to keep the ‘pick-up’ fuel less turbulent, to enable easier pumping.
    Build 2: Mk5 Complete kit | Coyote Gen 4X | TKX | IRS | Brake Booster | Traction Control | Ordered: 3/18/2026 | Build Thread
    Build 1: Mk4 Roadster | Coyote Gen 4X | Ordered: 1/31/2024 | Delivered: 4/11/2024 | First Start: 8/9/2025 | Legal: 11/5/2025 | Crashed: 2/16/2026 Build Thread
    OTOH putting it into the pickup pan helps keep the pan full during cornering.
  4. Likes weendoggy liked this post
    Aptos, CA
    Stock Fox bodies did the same. My stock pan has been like that for 26yrs, no issues. Also, on my '02 Coyote swap Mustang, I put the return into the "fuel sump/pump" can (center of tank) and can run that down to less than 3gal on track. Before that change, maybe just below 1/2 tank before having starving issues in corners.
    I'm just a victim of a thousand physic wars!
    www.weendoggy.com/cobra.htm
    O'Fallon, MO
    That is how it should be.
    As a second note, the returning fuel is thought to help keep the pump cool. I have no proof of that, but I've seen that idea posted about.
    Houston, TX
    I stand corrected.
    Jan 2019
    Mead Colorado
    Thanks all!
