77
148
misc upholstery prep
Hey Y'All,
After getting some parts ready for the Powder Coater, I didn't get much else "significant" done on my build this weekend
"Slow-n-steady" progress being made, though. This post shows some miscellaneous upholstery prep that most of you have done...
First up: adding self-adhesive thermal padding to my drop trunk
Then, I focused on the trans tunnel top panel...with top and bottom prepped
Bottom-side got an aluminized fiberglass self-adhesive pad
Top-side got a self-adhesive 1/8" thick closed-cell foam pad
and lastly, I ran out of time, but did manage to start on a template for the upper trunk floor
I'm hoping I can use this for both the thermal pad and the carpeting
Until next time, Happy Building!
Craig C
