Results 1 to 4 of 4
Thread: AutoCad or Visio Files of Electrical Schematics
    Sep 2024
    Spencerport, NY - near Rochester
    I'm about to pull the trigger on buying Visio so I can redraw the FFR electrical schematics to create a clean drawing reflecting my changes, adds, removals, integration of the EFI harness, etc. Before I start from scratch I thought I should ask here if anyone has a file already. I'm sure someone out there has done this already, but searches aren't surfacing anything.
    If in AutoCAD It would need to re-saved to 2007 (yes 2007!) in order for Visio to import it and convert it. I can't use AutoCAD because I don't have the license or the skills, and it's pretty expensive. I can get Visio for a reasonable cost and I think it will do everything I need to do to recreate the schematics.
    Pat
    MK4 complete kit Nov 2024, Blueprint 347, TKX, Hyd clutch, IRS, 3.55, touring shocks, 17" wheels, 11.65 brakes, Build Thread
    Feb 2024
    Outside Boise Idaho
    Quote Originally Posted by PMD24 View Post
    Pat
    Hi Pat,
    I use draw.io (https://www.drawio.com/) for my diagraming as it is free and has most of the features that Visio has. If you decide you want to try it let me know and I can share what I have done (a pdf is posted earlier my build thread https://thefactoryfiveforum.com/show...l=1#post578213 ).
    Best Regards, Andrew
    Sep 2024
    Thanks Andrew. I recall your diagram. Printed it for reference. I'll check out drawio.
    Pat
    Sep 2024
    Louisville, KY
    I will second the drawIO recommendation. I used it to create master power and grounding point schematics and then imported them into a PPT/PDF. It felt cheesy like I was making a presentation (because I was), but I also felt like that was the format that I wanted it preserved in. Eventually I will post it once it is tightened up.
  5. Thanks PMD24 thanked for this post
