The lower radiator hose is much more difficult, thanks to the ill-thought out angled water neck on the radiator that points directly into a frame member. Also in the way is the sway bar, battery, and a bunch of other frame rails.
I pieced together a pathway out of aluminum tubing from Amazon, silicone couplers, connected by Gates Powergrips. The aluminum tubing has beads on them, otherwise I think the connections would slip. This was primarily trial and error until I got something that would fit.
Then the last leg to the thermostat housing is the AN hose
Looking back to do this write-up, it's no wonder it's taken me forever to get to my current stage in the build.
