Finally set the body on the frame for the first time. Will need to come off to do some trimming. Looks like there is trimming needed on the backend. The rear doors sit about flush with the striker plate. And my frame extensions will need to be adjusted a bit once I get the body centered. But so far it doesn't look too horrible.
Here are some fun photos of all the foam and bulb seal. I did put painters plastic over the bulb seal.
I think the next step will be taking the wheels off and centering the front so I can measure for a brake reservoir firewall bracket. Then pull the body trim and try again.
