Results 1 to 6 of 6
Thread: Steering Shaft
    Mar 2021
    Ohio
    Steering Shaft
    Anyone know what grade of steel the steering shafts are made of? I need to make one that is a couple of inches longer to accommodate my dash design.
    Norton, MA USA earth
    Not sure but maybe it would be easier to just buy a longer DD shaft that the steering shaft slides into.
    Mar 2021
    Ohio
    That is an excellent idea, I did not think about it from that end. Do you know of any good sources for it? It does not seem to be as readily available as the solid shaft. I see one from Holley that is black, but I was trying to stick with the natural finish.
    Brent
    Mar 2021
    Ohio
    Looks like this is an option: https://www.borgeson.com/1-DD-Shaft-36-Long.html. It looks black in the photo, but after talking with them on the phone, they said it is just raw steel. This is also an option that has black zinc coating.
    Southern Ontario/Cape Coral FL
    Amazon, Speedway, Summit. You can get those in different lengths almost anywhere.
    Higgy
    MK4 #11354 picked up 10/06/25
    MK4 #11173 picked up 01/20/25
    MK4 #11012 picked up 04/16/24 SOLD
    MK4 #10616 picked up 4/10/23 SOLD
    MK4 #9759 picked up 4/3/19 SOLD
    Nov 2020
    Damascus OR USA
    Summit Racing has them in varying lengths. I saw both 24" and 36".
