Results 1 to 11 of 11
Thread: Mk5 Shifter Ring and Brake Ring Placement Issue
    Feb 2025
    Just noticed that there is not enough room for the shifter ring and emergency brake ring for my Mk5. Has anyone else noticed this?
    You can flip the shifter tower 180 degrees moving it to the more forward rear position. If you do that you may want a different lever.
    Loveland, CO
    I just flipped mine to the forward position and it still overlaps some. I understand some engines are shorter than others, and that makes some difference. But my SBF and TKX looks like it will not totally clear. Some have gone to the full forward position (for some reason called the midskhift position), but I think that is more involved and may take some parts.
    Fun, fun. Ralph
    May 2022
    Build School: 5/2/2025
    Complete kit order: 5/8/2025, Delivery: 5/31/25, BluePrint 347 EFI + PS + AC order: 5/2/25 Delivery: 8/14/2025
    YouTube Channel
    Just cut one of the trim rings to fit against the other
    Aug 2022
    Portland, Oregon
    Just a thought here, put a spacer in the shift handle bolts to move the shift handle over to the left and are you able to maybe add a spacer to the park break to move it over to the right. Then arrange the trim rings to the extreme position.
    Sep 2022
    Quote Originally Posted by F500guy View Post
    That's what I did on my MkIV ... to the shift lever anyway
    You could also "build your own" trim rings https://thefactoryfiveforum.com/atta...3&d=1775408912
    Good luck!
    Craig C
  8. Likes jbryant liked this post
    Feb 2025
    Thanks everyone for your ideas and suggestions. I took Jeff's advice and moved the shifter forward. Now I need to find a shifter lever with less forward tilt.
  10. #9
    Feb 2025
    Craig C - That trim ring looks great! Unfortunately, I don't think I have the tools, or talent, to manufacture something like that.
  11. #10
    Jun 2020
    Rising Sun , Md.
    I didn't care for the FFR shift lever and I found Hurst makes various lengths.hurst.png
    FFR 9883 MKIV ,427 Windsor engine
    TKX 5 speed, Three Link 3.55 gears
    Power Steering, Leather Seats
    18" Wheels and Tires, Drop Trunk
    Fun Package
  12. #11
    Sep 2022
    Quote Originally Posted by jbryant View Post
    I didn't use any special tools...and my hand dexterity limits my "talent"...and it did take a while, but you can do it, too! Maybe on your next build...
